brakes>bleeding #522278 11/05/04 01:21 AM
RQF4 Offline OP
I just put new lines on.... not factory though (toyota couldn't mach them!?) So I used a 60' and a 51' together...refilled my master reservoir and started bleeding the lines at driver rear and so on...
well, I'm not getting any preshure!?
Iv'e gone around a bunch bleeding at each wheel and there spiting juice, no air..... my lines don't seam to be leaking eather, what gives? Any ideas?? I'm thinking there might be air stuck somewhere in or near the master cylinder..?...Thanks -Corey
1988 SR5 x-cab 4x4 w/22-re -mod's- custom cold air intake, red top optima, lo-pro bump stops, thorley header, high flow cat, 2.5 exhaust, dynomax muff, chevy springs, procomp shocks .....
Re: brakes>bleeding [Re: RQF4] #522279 11/05/04 04:03 AM
rednekbean Offline
Check the adjustment in the drum brake. if it is out of adjustment the peddle will feel soft with no pressure.
nick
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
Re: brakes>bleeding [Re: rednekbean] #522280 11/05/04 05:08 AM
RQF4 Offline OP
cool, I'll check tomorrow and also just try to keep bleeding.... maybe there are some small bubbles in there that will settle out tonight.... Thanks -Corey
Re: brakes>bleeding [Re: RQF4] #522281 11/05/04 05:35 AM
Stan_Marshall Offline
also, how sure are you that the master cylinder is good?
are you replacing the lines because one of them ruptured and the brake pedal went to the floor? if so, that causes the mc to compress much further than usual. as a result, the seals inside slide against metal they have not rubbed against (and kept clean) in a long time. this can ruin the seals. (had it happen to me once.)
1994 4x4 22RE W56 truck
Re: brakes>bleeding [Re: Stan_Marshall] #522282 11/05/04 05:38 AM
also, i just noticed you mentioned refilling the master cylinder. did it go completely dry during the process? if so, you might should take it off and bench bleed it. and make sure the seals are still good.
Re: brakes>bleeding [Re: RQF4] #522283 11/05/04 07:22 AM
Robinhood150 Offline
Did you bleed the LSVP too?
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: brakes>bleeding [Re: Robinhood150] #522284 11/05/04 09:56 AM
Did you use the FSM sequence recommendations for bleeding? <img src="/forums/images/graemlins/notooth.gif" alt="" />
shaggy
Re: brakes>bleeding [Re: RQF4] #522285 11/05/04 05:06 PM
Marc91runner Offline
Recently I changed my callipers and could not bleed my brakes properly. I tried for 3 days and couldn't get a good pedal. I've bled brakes successfully many times.
I finally took it to a brake shop and they bled them perfectly. ????
'91 4Runner SR5 V6 4X4 Auto, A/C (self installed)
4.56, 31x10.5x15 Nokian Vatiiva's
Re: brakes>bleeding [Re: RQF4] #522286 11/05/04 05:44 PM
Myota Offline
Corey,
When I replaced the two main lines that run to the rear, I had exactly the same problem. When all the fluid ran out of the system, it took sediment that was in the bottem of the master cylinder, past the seals. When I refilled and started bleeding the system, I found I couldn't get any pressure to build up. After replacing the MC, I had no problem bleeding the rest of the system. You should check your MC for worn seals and rebuild if need be.
-Chris
'88 EFI Xtracab, 32 x 11.50 Buckshots, AZ bed, Turbo drivetrain.
Re: brakes>bleeding [Re: Myota] #522287 11/05/04 06:29 PM
Red_Chili Offline
Toyota Section Staffer
For heavens sake use a pressure bleeder or vacuum bleeder. Saves a headache. Saves bench bleeding too... Search reveals all.
-Bill
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6358 MB (Peak: 0.7581 MB) Data Comp: Off Server Time: 2026-06-17 04:11:38 UTC
