Idle surges w/ brakes :( #522610 11/06/04 02:47 AM
kmat123 Offline OP
When my truck is at idle and I apply the brakes, my idle begins to surge from 750-1250 rpms. When I let off the brakes my idle returns to slightly higher than normal (~1000 RPMS). Any ideas on what this could be? <img src="/forums/images/graemlins/confused.gif" alt="" /> Thanks guys!
Re: Idle surges w/ brakes :( [Re: kmat123] #522611 11/06/04 02:53 AM
4Crawler Offline
What engine?
There were several recent L O N G threads on this topic, try the search button to find them. Could be a vacuum leak from the brake booster, but more likely its the idle speed set too high. Here's a recent question/answer from the Toyota Trails Truck Tech column:
QUESTION:
I have a 94 4wd p/u w/ 22re. My engine runs great, except for when it is idling and I depress the brake pedal. The engine then idles really weird, kind of a strong then weak then strong then weak, so on and so forth. It never cuts out, though, and continues to idle normally when I take my foot off of the brake. I've only noticed this after driving, like at a stoplight.
ANSWER:
Assuming there are no vacuum leaks, such as in the brake booster, it's likely because your idle speed is set too high. I can exactly duplicate this "problem" in my '85 by bumping up the idle speed to a bit over 1000 RPM and it'll act as described. Turn the idle speed back to normal, and it works fine. It's really not a problem, its supposed to work this way and if everything is set properly, and you won't have the "problem".
Why is this the case? Because the ECU has logic built in that says if you hit the brakes and the engine is turning over 1000-1100 RPM, it'll cut the fuel to the injectors in an attempt to help you stop faster. After all, no sense pumping gas into the engine when you are braking to a stop. So idle rises, fuel is cut, idle falls, fuel restored, idle rises, etc. Turn the idle back to 850-900 RPM where it's supposed to be and it'll get back to normal. Idle speed is adjusted with the large slotted screw atop the throttle body. Turn it in to lower the amount of air passing through the throttle body at idle (and thus lower the idle speed).
If you don't want to do that or it doesn't fix the problem, here's a more drastic fix:
http://www.geocities.com/toyotashawn/bizzareidle.html
Which basically involves cutting the wire that feeds the brake light signal to the ECU. Without that input, the ECU will never know you are braking, so it'll not be able to cut off the fuel injectors.
Re: Idle surges w/ brakes :( [Re: 4Crawler] #522612 11/06/04 03:01 AM
kmat123 Offline OP
Thanks for your quick response roger! I have seached quite a bit on this topic and turned my idle screw all the way in, which causes the idle to start at around 750 rpms. However, after driving for a few minutes it raises to ~1200 rpms and I get the surging idle upon breaking.
Re: Idle surges w/ brakes :( [Re: kmat123] #522613 11/06/04 03:19 AM
4Crawler Offline
Throttle stop set too far out or something preventing the throttle from closing fully or a vacuum leak. Something is letting in too much air at idle, forcing the idle air screw to be turned in all the way. Also, check your TPS idle setting and make sure its correct:
TPC setting
Then make sure the timing and idle speed are properly set.
Re: Idle surges w/ brakes :( [Re: 4Crawler] #522614 11/18/04 06:52 PM
kmat123 Offline OP
Well I took the throttle body off my truck, cleaned it out and cleaned and adjusted the TPS. However, I still had the idle problem. Then on Satuday I replaced the thermostat, dissasembled and flushed the idle air control valve and flushed my coooling system. Now the idle is perfect! I don't know which of these was the culprit, but I'm just glad that I finally figure it out. <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6112 MB (Peak: 0.6937 MB) Data Comp: Off Server Time: 2026-11-16 01:24:31 UTC
