Injector O-rings... Toyota? #522996 11/07/04 06:12 PM
W
wave Offline OP
Ok, so the heads are off, machined and waiting for the gaskets to come in.
Now on to the injectors, this is my DD so I do not have time to send away the injectors. I need to get new o-rings for them before I put it all back together. The manual (online autozone) says to replace the grometts and insulators along w/ the o-rings. All of this from Toyota is $140. Seems a little steep for 18 o-rings, 6 grometts and 6 insulators.
The question...
can I reuse the grometts and insulators, and where can I get o-rings besides toyota? None of the parts stores have the o-rings listed, so does anyone know the specific sizes needed?
95 3vze 165,000 miles.
Thanks again!!!!
Anthony
Re: Injector O-rings... Toyota? [Re: wave] #522997 11/07/04 06:25 PM
Vonka Offline
I changed my friends Tacoma injectors to the URD type.It had new O rings and I used the other parts from the old injector to complete assembly.Make sure they are in excellent shape.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: Injector O-rings... Toyota? [Re: wave] #522998 11/08/04 02:06 AM
CJM Offline
they are avaliable aftermarket ...
I just got mine done $100.00 CDN including orings and insulators , mind you its for a 4cyl .
sorry for the blurry image .
83 Trekker SR5
NEW Trekker forum
Re: Injector O-rings... Toyota? [Re: wave] #522999 11/08/04 03:09 AM
Snowtoy Offline
Depending on where you are at, you should be able to have the injectors cleaned and/or rebuilt locally, or within driving distance.
Re: Injector O-rings... Toyota? [Re: Snowtoy] #523000 11/08/04 04:08 AM
J94_4runner Offline
I think i have 6 injector "insulators" avail, new. I ended up over buying 6 of them. As for the O rings on the top of the injectors.. no idea. If you are interested, let me know.
www.celicasupra.com
Re: Injector O-rings... Toyota? [Re: wave] #523001 11/08/04 04:04 PM
mxitup Offline
NWOR sells the kit you are looking for. It includes all the o-rings, insulators, grommets, copper washers for fuel delivery lines as well as a throttle body gasket for $25.
Give them a call.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6086 MB (Peak: 0.6783 MB) Data Comp: Off Server Time: 2026-06-13 10:50:58 UTC
