Need info on manual hub #523226 11/08/04 03:15 PM
Can anyone please give me some info on "Warn Manual Hubs". I would like to change the factory vacuum hubs with Warn Manual hubs. What are the advantages and disadvantages in switching over? Where can I buy them? How much are they? Do I need special tools? Any information is greatly appreciated.
Re: Need info on manual hub #523227 11/08/04 04:37 PM
rngrpower Offline
I got mine from Advance Auto Parts. They had to order them but they came in like 2 days. $104
Just follow directions that come with them.
Un-bolt old ones, when bolting on new ones only use the lock-washer, leave flat washer off.
Then, disconnect the plug from the vacumn solenoid.
Only draw back is you have to get out and lock them in.
However, at least when you lock them in they are locked. On vac ones, if solenoid went bad, no 4x4. If a vac line broke or leaked, no 4x4. The manual are to me more reliable.
(unless you forget to lock them in and rolled backwards down into a tree. not me , friend in a nissan p/u)
Anyways, they will work for you. [Linked Image]
Re: Need info on manual hub [Re: rngrpower] #523228 11/08/04 04:59 PM
fokion Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> You reminded me that I have towed a car stack on the snow and when I reached clear ground I descovered that eventhow I had engage 4x4 I had forgot to lock them!!!! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
If forsee that you will need them you can lock them before ( say 10 KM prior - what I do ) (eventhow some say that you can make more distance with them locked and with 2wd) with the dissadv. of increased drag and gas consumption.
Re: Need info on manual hub #523229 11/09/04 12:38 PM
I had my mother-in-law in the sporty when I discovered my vaccuum hubs failed, need I say more?
Got mine at Carquest for about the same $105ish, haven't missed a shift into 4-wheel since. 6 10mm bolts per side.
Re: Need info on manual hub #523230 11/09/04 11:16 PM
DamKia Offline
Kia Moderator
[Linked Image][Linked Image][Linked Image][Linked Image]
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6045 MB (Peak: 0.6844 MB) Data Comp: Off Server Time: 2026-05-29 15:01:29 UTC
