Error codes.... Fuel pump???????? (update) #523307 11/08/04 09:15 PM
sparkem Offline OP
I finally got my Raider to give me an error code from the ECU. It is still sputtering, if I hold my foot on the gas, it eventually dies. Then the check engine light comes on. I checked the code with a volt meter, it gave me 42, which is Fuel pump. Does that mean the pump is bad? Could it be the fuel pressure regulator? How do I check these two things to see which one is bad? What would trip the Fuel pump code?
Re: Error codes.... Fuel pump???????? [Re: sparkem] #523308 11/08/04 10:28 PM
Lloyd Swartz Offline
Survey says, its the fuel pump. You can pull the hatch in the back and see if you hear it run when someone turns the key to on, and put a test light on the plug to see if it lights up. The pump only gets power for a second when you turn the key though.
Re: Error codes.... Fuel pump???????? [Re: sparkem] #523309 11/09/04 12:54 AM
1991monterols Offline
When i put my foot on the gas mine would die too, and then i replaced the fuel pump and all went away
nate
1991 Montero LS 5sp with 32s on black 15x8, snorkle, roof rack, 9000lb milemarker, cb, 4 hella lights sold
1991 Montero RS Auto on 35s, 2in BL, hella lights, cb, roof rack blown headgasket
Re: Error codes.... Fuel pump???????? [Re: 1991monterols] #523310 11/09/04 06:49 AM
sparkem Offline OP
I know the pump works, well sometimes, because the truck runs fine for a little while. The wires look good. I guess I will get a new pump. I dont want to go spending money if that is not the problem.
Re: Error codes.... Fuel pump???????? [Re: sparkem] #523311 11/11/04 11:33 PM
TobyB Offline
well, then, put a meter on the fuel rail, and see if it's holding pressure (it should fluctuate with inlet manifold vacuum, but stay pretty high).
If not, then tee off before the regulator to see how it's doing (this is a major pita- mitsu has a kit, but I doubt mere mortals could get their hands on it)- if that point holds steady (high) pressure, it's your regulator. If not, it's the pump. Put a meter on the pump power terminals- sometimes the relay will only work intermittently...
hth,
Toby
'89 V6 4dr- '4- Doris'
Re: Error codes.... Fuel pump???????? [Re: TobyB] #523312 11/12/04 02:13 AM
pmontero Offline
Hey Sparkem,
I may have dropped the ball a while ago... I've been pretty busy lately! Didn't we talk about me sending you an MPI relay to try out? If you still want me to send it to you, PM me and I'll get it out asap.
Powell
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
Re: Error codes.... Fuel pump???????? [Re: pmontero] #523313 11/12/04 04:15 AM
sparkem Offline OP
I tried the MPI relay out of the montero and it did the same thing. I bought a new fuel pump and that seems to be the problem. It has not messed up yet. I hope it stays that way. Thanks for all the help guys. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Error codes.... Fuel pump???????? [Re: sparkem] #523314 11/17/04 08:34 AM
sparkem Offline OP
Guess what messed up today...... POS. It is giving me the fuel pump code and now the ECU flatline. Dammit. I got that ecu off of ebay. I hope that works.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6236 MB (Peak: 0.7066 MB) Data Comp: Off Server Time: 2026-06-22 06:11:15 UTC
