Building pressure in the Clutch lines.... #523742 11/09/04 06:39 AM
ArbitraryNotion Offline OP
I have the problem lately that pressure builds between the clutch master and slave. Every few days I have to open up the slave bleeder and let off the pressure...
I guess this is a warning to all you guys that use Autozone and equivient parts.
Josh
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: Building pressure in the Clutch lines.... [Re: ArbitraryNotion] #523743 11/09/04 06:58 AM
Manson Offline
Make sure the pushrod for the master cyl isn't adjusted too long. If the master is depressed just a little with the clutch pedal up it cannot bleed off pressure. Oil in with the brake fluid can cause problems also.
Re: Building pressure in the Clutch lines.... [Re: Manson] #523744 11/09/04 07:20 AM
Could you clarify "long"?
I currently have the longest travel possible with it adjusted all the way in twards the pedal itself. Let me know if this is what you ment.
Josh
Re: Building pressure in the Clutch lines.... [Re: ArbitraryNotion] #523745 11/09/04 07:33 AM
stock87 Offline
Long is fine, just make sure there is no pressure exerted on the MC when the pedal is all the way out... i.e. it can release fully with the pedal out.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Building pressure in the Clutch lines.... [Re: stock87] #523746 11/09/04 08:55 AM
One thing that will cause it fersure is moisture in the fluid.
If you ain't never done it, next time you bleed the slave go ahead and flush all the old fluid out with fresh stuff.
Re: Building pressure in the Clutch lines.... [Re: ArbitraryNotion] #523747 11/09/04 01:36 PM
ACES_HI Offline
This is why im replacing my fourth Foreign Autoparts master
with a OEM Aisin. Im getting tired of replacing it once a year!
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: Building pressure in the Clutch lines.... [Re: stock87] #523748 11/09/04 10:16 PM
It starts off being able to close all the way but as it builds pressure in the lines, it stops working correctly and if I don't release the pressure the clutch won't fully close.
I'm going to look up how much it costs for the $tealership parts...
Josh
Re: Building pressure in the Clutch lines.... [Re: ArbitraryNotion] #523749 11/09/04 10:27 PM
What are you using for hydraulic fluid?
Re: Building pressure in the Clutch lines.... #523750 11/10/04 01:24 AM
DOT 3 Brake fluid. It was changed out a few months ago when I installed the new master cyl from Autozone. I've blead it completely several times since. I just keeps building pressure.
Josh
Re: Building pressure in the Clutch lines.... [Re: ArbitraryNotion] #523751 11/10/04 03:11 PM
dknight Offline
Josh
You have to have freeplay. If you don't you'll have pressure buildup just as you describe. I don't remember the spec, but as long as you have a little freeplay you should be OK.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6365 MB (Peak: 0.7579 MB) Data Comp: Off Server Time: 2026-06-07 07:18:13 UTC
