Check engine light
#523971
11/09/04 09:20 PM
Also my check engine or egr light is on. Is ther an easy way to pull the codes on these Raiders? I would assume that the brains on these things are that high tech.
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15 I caught this "JEEP thing" of your and now it hurts when I pee.
Re: Check engine light
[Re: juggernaut]
#523972
11/10/04 12:02 AM
The codes are pulled with a old analog voltmeter. You count the times the needle swings back and forth. I think there is a write up in the archives.
[Re: juggernaut]
#523973
11/10/04 01:39 AM
go to the main mitsubishi section and go to the tech articles
1991 Montero LS 5sp with 32s on black 15x8, snorkle, roof rack, 9000lb milemarker, cb, 4 hella lights sold
1991 Montero RS Auto on 35s, 2in BL, hella lights, cb, roof rack blown headgasket
[Re: juggernaut]
#523974
11/10/04 03:06 AM
I would imagine you hit the "every 50k service light"
There is a switch behind the guages to shut it off. Nothing high tech about it.
[Re: LandRaider]
#523975
11/10/04 11:09 PM
I guess I missed it. Looking at tech on front page but nothing about check egr or error codes. Thanks for helping the noob.
[Re: juggernaut]
#523976
11/11/04 12:55 AM
I believe someone has previously made the distinction between the "check engine" light and the "maintenance required" light. The latter can be turned off by pressing a button (do a serch). The former can indicate a multitude of sensor/performance malfunctions. If the "check engine" light is coming on, try clicking here. -DougB <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: DaphneD]
#523977
11/11/04 01:04 AM
I believe someone has previously made the distinction between the "check engine" light and the "maintenance required" light. The latter can be turned off by pressing a button (do a serch). The former can indicate a multitude of sensor/performance malfunctions. If the "check engine" light is coming on, try clicking here. -DougB <img src="/forums/images/graemlins/cheers.gif" alt="" /> But his sig say 87 Dodge Raider. My article is for the fuel injected v6. Isn't the only computerized component inside the dizzy on a 4 banger? PHIL
[Re: PHIL_]
#523978
11/11/04 05:38 AM
Thanks and it is the check egr light. I was thinking of jeep with the ckeck engine light. Sorry for confusion.
4 banger computer
[Re: PHIL_]
#523979
11/11/04 11:03 PM
no, there's an ecu on the 4 cyl with carb. That drove me nuts- the carb does most of the work, but the computer and o2 sensor fine- tune the mix with a mini- injector to compensate for changing conditions and wear.
And so you get the worst of both worlds- fussy carb and inscrutable computer. Thing seems to work pretty well, though, most of the time... just heinously inelegant.
t
'89 V6 4dr- '4- Doris'
