Page 2 of 6 1 2 3 4 5 6
Re: truck wont hold coolent [Re: 2utadud] #524896 11/12/04 08:51 PM
2
2utadud Offline
truck is diff. i drive it for about 10-15 miles @ 70 mph and
temp gauge starts going to middle. when i slow down, temp goes down to normal level. coolant drains but not to reser-
voir. no leaks found. is this pointing to hg too?
Post deleted by little_joe #524897 11/12/04 09:22 PM
Re: truck wont hold coolent #524898 11/12/04 11:48 PM
As the gasket fails, it might first fail to where the higher pressure combustion gas blows into the cooling jacket. That's why it will force your coolant out of the radiator into the reserve tank.
Once it's really good and blown, and after you refill the rad, it will also suck coolant into the combustion chamber on the intake stroke....the coolant burns and smokes white......Or, once the engine is stopped, the pressure in the cooling system will force coolant into the now depressurized cylinder where the gasket is blown or head is cracked, and then it will smoke when started and also blow into the radiator.
For the guy with the blown HG on the7mge....that's a common failure for that engine....It ain't no cheap fix when compared to the 22re. So you really should do some homework before you do it or have it done to make sure it stays fixed.
Re: truck wont hold coolent [Re: 2utadud] #524899 11/13/04 01:09 AM
4Crawler Offline
When I had problems with a partially clogged radiator, I would get that type of symptom. Engine started to run hot/overheat if it was hot outside (75F+) and speed > 65 or RPM > 3500. If I slowed down on the flats or if on a hill and shifted to a higher gear (lower engine revs) the temperature would drop. New 3-row radiator and it was fine.
Re: truck wont hold coolent [Re: 4Crawler] #524900 11/13/04 05:11 AM
well thanks guys you are awsome...i got a hg today.. its 11 pm. and im about to start the project.... i hope its a hg.... but i guess ill find out.... but thanks again for all the help........ i owe you guys one
oh and when i accelerate i can also hear a gurgle sound underneath.. i was just thinking aliens were under there sucking away my antifreze..... i guess not........
Re: truck wont hold coolent #524901 11/13/04 05:29 AM
kewlynx Offline
Don't forget to change your oil, Juuuuust in the off chance you might've gotten some contamination. Any milkshake on the oil cap?
**ubi apis- ibi salus**
Re: truck wont hold coolent [Re: kewlynx] #524902 11/13/04 07:16 AM
nope checked it and looks fine..... but i also checked the plugs and they look nearly perfect,,, one is a touch lighter colored but for the most part the same.... i dunno whats going on..
Re: truck wont hold coolent #524903 11/13/04 07:25 AM
4Crawler Offline
Gurgling sounds when revving the engine (w/ the heater valve open) were always a sign when I had HG leaks. NEver saw oil-coolant mixing. All the times I had this type of problem, it was always an exhaust->coolant leak except the initial time when it was a cracked head, in this case there was also coolant->exhaust leak and I would get lots of white smoke. But mainly it was the case of exhaust gas over-pressurizing the cooling system (and that exhaust gas making the gurgling sounds) and blowing the coolant out the overflow.
Re: truck wont hold coolent #524904 11/13/04 12:45 PM
G
GeriatricToy Offline
Geez, a gurgle, sounds to me like it's simply just an air bubble <img src="/forums/images/graemlins/confused.gif" alt="" />. I know just having air in the system you'll get all kinds of wierd chit going on. Iffin it wasn't for that smoke coming out of the exhaust, I'd say get the booble out.
2000 Tacoma SR5 - Bone stock 'cept a little bling.
2000 Tacoma SR5 - Bone stock.
Re: truck wont hold coolent [Re: GeriatricToy] #524905 11/13/04 04:18 PM
in reply to the milkshake on oil cap.... yes there is some on there.... what would that mean??????? hg?
PHP: 7.4.33 Page Time: 0.019s Queries: 16 (0.014s) Memory: 0.6362 MB (Peak: 0.7592 MB) Data Comp: Off Server Time: 2026-11-04 20:00:08 UTC
