What back spacing do I need to run 35s #525338 11/13/04 01:41 AM
tj93_51 Offline OP
I have a 93 trooper with a 3 inch body lift and 3 inch suspension lift and want to run 35s. I have two questions, first will a 15 inch wheel fit on my rig without any problems, and second what amount of backspacing should I get to reduce rubing? Thanks
1993 Trooper LS, 3" suspension, 3" body 285/75/16s, custom front bumper.
Re: What back spacing do I need to run 35s [Re: tj93_51] #525339 11/13/04 02:14 AM
Jim_Paget Offline
First, welcome to 4X4wire.
I would suggest that you use the search function. This subject is discussed regularly here. I did a seach using the following criteria: +backspac +35 and looked for the past year. I got a whole page full of hits.
I used the criteria backspac so that it would hit on either backspace or backspacing.
Good searching!!
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: What back spacing do I need to run 35s [Re: Jim_Paget] #525340 11/13/04 03:23 AM
chasespeed Offline
I have the same combo on mine, currently running 33s... and there is enough room for 35s... though I would stay close to a nuetral backspacing...like a 15x8, with a 4" b/s.. you should be good...
I know Drakemore is running 35s on his rig(another 2nd gen troop), though, I think he had to do a little trimming..
HTH
Chase
Chase
Re: What back spacing do I need to run 35s [Re: chasespeed] #525341 11/13/04 07:02 AM
Chris Perosi Offline
Isuzu Staffer Emeritus
The issue with the 35's will be the tie rods, not so much room in the wheel wells with the lift you have. You might need some trimming/flares/etc, tho. Use the search and see what you find cause I don't really know off the top of my head about the backspacing and such. Think seriously about investing in something like the tie rod shieldz from <a href="www.darlington-offroad.com" target="_blank">Darlington Off-Road</a> and, of course, buy yourself a coupla spares and learn to change them in compromising positions under your front end, sitting in 6 inches of mud. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Chris Perosi
Isuzu Editor Emeritus
OutdoorWire, Inc.
Re: What back spacing do I need to run 35s [Re: Chris Perosi] #525342 11/13/04 04:02 PM
matthew Offline
i like 3 3/4" on a 15x8 with a 35x12.50/15
good combo for the troopers.
oh and welcome <img src="/forums/images/graemlins/cheers.gif" alt="" />
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6078 MB (Peak: 0.6727 MB) Data Comp: Off Server Time: 2026-06-07 07:18:31 UTC
