Compressed air storage solutions #525343 11/13/04 02:09 AM
G
Germ Offline OP
Hi all,
I may have access to some uncertifiable oxygen cylinders (E cyl) that can no longer be certified for medical oxygen use, but are still in good condition. They are rated for 2200 psi, and should easily be able to handle 100-250 psi that we would use. The only dilema would be figuring out a manifold for it, but I have some ideas.
I'm not sure how much they would cost, and the supply would be sporadic at best.
How much interest would you guys have in such a thing? I'm trying to figure out if it is worth pursuing or not. Please let me know. If there is enough intrest (6-7 people?), I'll figure out pricing and see what I can come up with for a manifold.
Thanks
Erik <img src="/forums/images/graemlins/cheers.gif" alt="" />
I would be interested
single choice
Votes accepted starting: 11/12/04 06:00 AM
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did.
85 4Runner, New motor, Dual cases, 4.88's, ARB's (F/R), 4" lift, 33's, Warn M8000#.
Re: Compressed air storage solutions [Re: Germ] #525344 11/14/04 07:34 PM
larsdennert Offline
My initial feeling is that they would be overkill. Too much weight for the air capacity they hold. I'm basing this on my experience with scuba cylinders which hold 2400-3500 psi depending on the model. Divers often use an air chuck and their regulators to fill tires. A filled scuba tank holds 80cuft generally. Fire extinguishers make a better option. See Roger Brown's site. They are light and hold about 200psi. At 100 psi you've only got a couple of cuft of 1atm air.
Good thinking though. It's nice to adapt "waste" to another use.
Re: Compressed air storage solutions [Re: larsdennert] #525345 11/17/04 09:47 PM
G
Germ Offline OP
I think I would have 2 options. One would be a steel tank (which I agree would be heavy) the other would be aluminum, which only weighs a couple of pounds.
Looks like there is adequate interest for me to do some more research, so if your interested, send me a PM, and I'll see what I can do.
Re: Compressed air storage solutions [Re: Germ] #525346 11/18/04 05:00 AM
1
1FastSS Offline
I have a $30 air tank from auto zone. It does quite well. I refill it with my cig lighter air compressor. I've also seen tube bumpers sealed up and then fitted with a quick disconnect and pumped up to around 125psi. I thought that was cool..........
Maybe fill them with helium and float across the mud...:scratches head.....hmmmmmmm
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: Compressed air storage solutions [Re: 1FastSS] #525347 11/18/04 02:26 PM
Back in college when I was still living at home, one day I was moving my CO2 cylinder for my MIG welder around in the garage. My mother came out and made some comment about wasn't that awfully heavy. I said it was and that it was getting heavier as I used it since the gas was lighter than air and helped lift it when it was full.... Had her totally convinced! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 18 (0.006s) Memory: 0.6210 MB (Peak: 0.7345 MB) Data Comp: Off Server Time: 2026-07-09 19:01:33 UTC
