toyota 3rd member ?s. #47205 03/04/03 08:03 PM
2
2utadud Offline OP
How can you tell the difference between 85 3rd
member and the 86-95? Does the ring gear of the
86-95 need to be removed first to remove the cen-
ter pin just like the 85 or no? Why is it called
3rd member?
Re: toyota 3rd member ?s. #47206 03/04/03 08:34 PM
gota87toy Offline
here's some good Toyota axle info-
A thrid member is a term for a removeable center section like those on Ford 9" and Toyota rearends. The entire hogshead casting and gear set/carrier is removed as a unit for setup or sevice.
Axles like a Dana 44 or GM 14 bolt must be service in the axle housing thru a cover plate on the back of the axle.
later
<small>[ March 04, 2003, 02:34 PM: Message edited by: gota87toy ]</small>
"Nine-11 changed me," he said. "I'm shocked that it didn't change the whole country, frankly."
Dennis Miller
Re: toyota 3rd member ?s. #47207 03/04/03 08:34 PM
all 8" 4cyl 3rd members are the same
PHP: 7.4.33 Page Time: 0.009s Queries: 14 (0.006s) Memory: 0.5928 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-11-16 08:42:54 UTC
