dohc or sohc #527043 11/16/04 10:52 PM
E
EricsTJ Offline OP
Was the 3.2L DOHC and SOHC engine installed in the 1994 Trooper? Are both called the 6VD1?
1997 Wrangler TJ 5 speed, 2.5 L. Mostly stock except for 31x10.50's on Black Rockcrawler Rims.
1998 Wrangler TJ 5speed, 4.0L. Rusty's 3.5 " lift,33"BFG,4.10 gears,Novak transfer case shifter
Re: dohc or sohc [Re: EricsTJ] #527044 11/16/04 11:28 PM
yeah, you could have either. the DOHC should say DOHC right on the top of the intake manifold, though. and the TB is pointing toward the front of the engine.
I believe both are called 6VD1...I've seen them listed with a superscript 1 or 2 to differentiate between SOHC and DOHC.
Re: dohc or sohc [Re: EricsTJ] #527045 11/17/04 03:58 PM
litnin Offline
The single cam motors are 6VD1 and the twin cam units are 6VD1-W.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: dohc or sohc [Re: EricsTJ] #527046 11/17/04 03:59 PM
smd94trooper Offline
I'm pretty sure that all the RS's have a DOHC. As for the LS and S, I have no idea how Isuzu made that decision. You can tell on the VIN what a truck has by the 8th number/letter. If it is a V - 6VD1-V SOHC, and if it is a W - 6VD1-W DOHC.
Stefan Doerr
'94 Trooper LS
6.5" lift, 33's, G80 and other stuff
http://community.webshots.com/user/smd94trooper
Re: dohc or sohc [Re: smd94trooper] #527047 11/17/04 04:37 PM
E
EricsTJ Offline OP
Thanks guys, I found the engine designation in the VIN last night--it is a V --SOHC.....
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6038 MB (Peak: 0.6637 MB) Data Comp: Off Server Time: 2026-06-09 21:59:38 UTC
