OME shocks/spacers? #528367 11/20/04 05:14 AM
Deron Offline OP
I'm going to be putting on 4 new OME firm shocks on my 2000 4Runner next month and I'd like to try and balance out the suspension while I'm at it. I love the OME HD setup that I've got but the driver side rear is 1/2" lower than the passenger side rear when the fuel tank is all but empty. It's not really noticeable but I'd like to put an OME 5mm or 10mm spacer on that side. The driver side front is a bit more than 1/2" lower than the passenger side front and is pretty noticeable. I'm going to be designing a dual battery setup and that will add a good 40+ lbs. to the driver side front so I'd really like to fix the sagging again with either a 5mm or 10mm OME spacer if possible. Does anyone know who sells the spacers? 4x4 Connection doesn't and Rocky Road Outfitters only sells 5mm spacers for the front and nothing for the rear. Anyone have any other suggestions for a fix? Has anyone else dealt with this on their 4Runners? Of course you don't notice any difference off road just on but I don't have the luxury of living life off pavement. Any suggestions are appreciated. I've considered going with adjustable coilovers up front but they simply aren't cost effective.
2000 4Runner, OME 882 front coils w/ firm shocks, 891 rear coils w/ firm shocks, Sonoran Steel adjustable rear panhard bar, ARB Prado bullbar, Warn 9,000lb. winch, Amsteel synthetic winch line, Hella Lights, 265/75R16 BFG All Terrains
Re: OME shocks/spacers? [Re: Deron] #528368 11/20/04 05:20 AM
I'm not sure why you are saying that 4x4connection does not sell them? I bought my OME rear trim packers for my 96 4Runner from them and they work fine. They leveled out my truck just as you are trying to do.
Re: OME shocks/spacers? [Re: Deron] #528369 11/20/04 05:53 AM
azrain Offline
Get on the phone with one of these guys:
Wheeler's Off-Road, Inc
541.474.2879 phone
10am-6pm Mo-Thu
or
Xtreme Off-Road & Performance LLC
623.566.3436
866.775.NUTS
Both shops can get you hooked up with what you need.
Mike
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5903 MB (Peak: 0.6443 MB) Data Comp: Off Server Time: 2026-06-07 03:07:11 UTC
