Rear brake probem. Help #529195 11/22/04 06:22 AM
TAucoin Offline OP
Alright i did my front brakes about 7k miles ago and there about 50 percent worn last time i looked at them. In the past year ive put 21k on my truck and the rear brakes are barely worn. What im thinking is the aal in the rear is making my LSPV think im braking hard everytime i touch the pedal and releasing my rear brakes. Does that make sense or am i just talking out of my <img src="/forums/images/graemlins/ignore.gif" alt="" /> ? I am going to clean and adjust the rear tom so maybe that'll help some.
Also, I saw Rogers LSPV mod and my second question is: If i disconnect my LSPV, will the rear end be as likely to lock up if i have ABS? Thanks for any help
Travis
Re: Rear brake probem. Help [Re: TAucoin] #529196 11/22/04 06:44 AM
ScottFW Offline
If the AALs made the rear a lot higher, the LSPV will think you have less load in the back of the truck and will reduce rear braking. It's not so much that the LSPV sees it as a hard braking situation. Should be a way to adjust the LSPV's arm to compensate, or you could remove the LSPV in favor of a manually adjustable proportioning valve (dial type) from Wilwood or the like.
'85 4Runner (mostly stock) <img src="/forums/images/graemlins/kewl.gif" alt="" /> | '94 Miata <img src="/forums/images/graemlins/smile.gif" alt="" /> | '98 Saturn SC2 <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> | '12 Ford Fusion (wife's company car)
Re: Rear brake probem. Help [Re: ScottFW] #529197 11/22/04 07:19 AM
And it ain't just ride height.......
Same-as-stock ride height with the new springs should make no diff in rear brake action, right?.....Wrong.
The new springs might ride at stock height, but allow more rear lift when braking....more rear lift means less rear brake action because proportioning valve actuating rod and linkage ain't been properly modified to match rear spring reaction to forward weight shift.
Do some measuring and the math and see if the new springs work with stock rear brake linkage geometry on paper. The worst that will happen is you get a headache and dull an already dull pencil. <img src="/forums/images/graemlins/smile.gif" alt="" />
I bet you can finger it out.
Re: Rear brake probem. Help #529198 11/22/04 09:55 PM
TAucoin Offline OP
Thanks for the help guys, Ill look into the Wilwood valve.
Hey Yodaddy, what part of louisiana are you from? Im moving to Houma in a month or two.
Re: Rear brake probem. Help #529199 11/22/04 10:01 PM
4Crawler Offline
Adjusting the LSPV is easy. If you have X" of lift, simply raise the bottom end of the sensing rod X". How? Easy, take a piece of flat bar steel (1/8"x1" works well) or even a piece of strapping steel from the hardware store. Mark and drill 2 holes to match the 2 holes on the end of the sensing rod bracket. Measure up X" and mark and drill 2 new holes in the extension bracket. Use the 2 stock bolts to attach the extension bracket to the axle, use 2 new bolts (5/16" or so) to attach the end of the sensing bracket to the end of the extension bracket. You have now raised sensing rod an amount equal to the lift.
Re: Rear brake probem. Help [Re: 4Crawler] #529200 11/22/04 11:09 PM
foxtrapper Offline
An even easier, and completely free, method is to just bend the rod.
Re: Rear brake probem. Help [Re: TAucoin] #529201 11/23/04 12:20 AM
My guess is, it has nothing to do with the LSPV. How often do you adjust your rear brakes? I would bet they need to be adjusted. Does your brake pedal go down farther than you think it should?
Re: Rear brake probem. Help [Re: TAucoin] #529202 11/23/04 12:33 AM
Then you will be just an 2-3 hour drive from cold beer and spicy BBQ! I'm near Alexandria Louisiana in the shallow rolling hills they call the terraced uplands that extend into Arkasas. The three P's are dominant here. Poor people, Pine trees and Politics. <img src="/forums/images/graemlins/smile.gif" alt="" />
But the fishing and hunting is good.
What will you be doing down in Houma?
Re: Rear brake probem. Help #529203 11/23/04 12:44 AM
TAucoin Offline OP
Well I'm only 19 so I cant LEGALLY take your offer for some beer, but BBQ sounds good. I lived in morgan city til I was around 10 or 11 and moved up here with my mom. I miss the bayou.
The only thing stalling me is my rearend, my gears have been making noise for the last 5 months and i dont want to make a 9 hour trip with a bad rearend. So now im in the process of building mine.
Re: Rear brake probem. Help [Re: TAucoin] #529204 11/23/04 01:42 AM
Welcome home!
Don't sweat the rear end too much. Tote enuff tools to drop the rear drive shaft if you need to complete the trip on just the front diff. Most injured diffs do ok just rolling and not actually driven by the prop shaft.
And if you break down near here we can certainly patch it up easy enuff.
318-640-8851......collect is ok for anyone under 21(been there). You older guys gotta dial direct, tho <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6281 MB (Peak: 0.7356 MB) Data Comp: Off Server Time: 2026-11-18 11:59:24 UTC
