SAS questions #529413 11/22/04 09:37 PM
SWORDFISH92 Offline OP
Would an fj-80 cruiser axle fit under a 92 4runner? reason i ask is its highpinion w/ a factory electric locker.
thanks,
Matt
1992 4Runner V6 SR5 4x4 Auto
-ARBequed, Geared, Lifted, Lighted, and Locked. 32 BFG KM's
Re: SAS questions [Re: SWORDFISH92] #529414 11/22/04 09:51 PM
4Crawler Offline
Its been done. Issues:
#1: You need to get special crossover steering setup, only 1 or 2 places make those.
#2: You need to do something for springs, either rig up coils like the FJ-80 uses, or cut that off and add spring perches for leaf springs.
#3: Axle is significantly wider than your rear axle.
Re: SAS questions [Re: 4Crawler] #529415 11/22/04 09:52 PM
kyle-22r Offline
you can always swap out the third member and put it in a pickup front axle
'91 4x4 shortbed
22R-E, W56, the dd!
Re: SAS questions [Re: 4Crawler] #529416 11/22/04 10:11 PM
It's a grat axle for a swap.
There is no need to due custom steering arms. The stock arms on it are setup for crossover steering. Just keep that system. You have the wider late model rear axle so all you need is a pair of rear wheel spacers to match it up.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5989 MB (Peak: 0.6585 MB) Data Comp: Off Server Time: 2026-06-20 17:54:08 UTC
