ubolt flip for waggy springs/toy axle #47517 03/06/03 04:53 AM
cronustrd Offline OP
Do i need a special width ubolt for running waggy spring with a toy axle? I know the waggy springs are a bit wider than the toy springs, but is this difference neglible?
can i just buy the ones allpro/rockstomper/sky..etc...sell?
2000 Toyota Tacoma TRD: 5" and 35s, Winch, Snorkle, Custom Sliders/Bumpers, Dana 44 and dual cases in the werkz...
1988 4runner: Formula Toy Meat...Got Sawzall?
Re: ubolt flip for waggy springs/toy axle #47518 03/06/03 04:57 AM
rob_dup1 Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by cronustrd:
<strong>
can i just buy the ones allpro/rockstomper/sky..etc...sell?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">yep.
Re: ubolt flip for waggy springs/toy axle #47519 03/06/03 06:01 AM
AOR flip kit did not fit my 7 leaf waggies at all. Springs too wide.I widend all 8 holes 1/4 (pain in butt) only to find out u bolt where too short, and I have no blocks or shims.They said they would send longer ones 5 weeks ago. $95 lost.I would say, before you purchase, confirm they will fit what you have. Or just make some.
EDIT:
AOR did send some longer u bolts no questions asked, and were very nice, although busy.
<small>[ March 07, 2003, 12:00 PM: Message edited by: SeanD ]</small>
Re: ubolt flip for waggy springs/toy axle #47520 03/06/03 02:19 PM
a buddy of mine just did his front with the waggies and the springs aren't that much wider..just take a grinder to the sides of the springs where the ubolts will be..he hasn't had any problems at all with doing his that way
Re: ubolt flip for waggy springs/toy axle #47521 03/06/03 04:11 PM
minor grinding, not an issue at all. I would recommend rockstomper.com Great quality
Re: ubolt flip for waggy springs/toy axle #47522 03/16/03 05:14 AM
If you have hy-steer, I would recommend Ford rear U-bolts from '88 F150s and up. You can pick up a set at a local wrecker for $20 (I did at least). The grinding thing also works. Good Luck
Re: ubolt flip for waggy springs/toy axle #47523 03/16/03 06:45 AM
Sky mfg--got mine there and they work fine, i asked sky if they'd work with heep springs (waggies or 44044s') and he said they drill them for the wider springs figuring they'll work for both toy & heep springs...
Re: ubolt flip for waggy springs/toy axle #47524 03/16/03 07:46 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Toyotafourwheeln:
<strong>a buddy of mine just did his front with the waggies and the springs aren't that much wider..just take a grinder to the sides of the springs where the ubolts will be..he hasn't had any problems at all with doing his that way</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Don't do this! Do it right. Napa can get you any size u-bolt you need. Napa is the best place to score u-bolts that I know of. Then just buy one of the readily available plates on the market or like Clay said, get the Sky stuff. I have ordered from Sky and they have great service and great products...
Re: ubolt flip for waggy springs/toy axle #47525 03/16/03 04:34 PM
DirtyHarry Offline
Toyota Moderator
I will add just a couple of comments here. First, I believe that the distance between the holes in the u-bolt plate are the issue here, not the u-bolts themselves. If something doesn't fit, I'd suggest modifying the plate, NOT the springs. You do not want to weaken your springs, plus it is a giant PITA to try and grind through spring steel.
Also, it is not advised to reuse old u-bolts as they have some "stretch" in the threads that keep them torqued down the first time they are used. I am not saying that no one reuses their old u-bolts, just that it is not advised. New ones aren't that expensive anyway.
It sounds like you can contact Sky or Rockstomper and get exactly what you need though, just let the vendor know what you are planning to do, it is not that uncommon a swap.
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.6133 MB (Peak: 0.7127 MB) Data Comp: Off Server Time: 2026-06-23 03:09:51 UTC
