EDIT....damaged cam, few questions. (Pics added a few posts down) #529490 11/23/04 03:14 AM
W
wave Offline OP
I am getting the truck back together now (95 runner 5sp w/ 3vze, that one little stray head bolt washer came in today from toyota, so the heads are now tourqued, got the manifoldas on, and the crossive and down pipe all bolted up. I started to put the cams in when I noticed that on my right cam on the #1 cap on the part of the cam the cap rests on, at the rear on the raised ridge, two pieces are broken off. I am assuming that this is important. Probably something to do w/ oil pressure and such. (will try to post pics tommorrow). I am guessing that I did not remove the cam caps in the proper order thus causing the damage.
1. Is this important?
2. does anyone have a spare cam lying around?
3. are cams like cranks in that each has a specific bearing size.
a. where do I find this info, or do I just get new bearings w/ the new cam?
Yep, looks like I'm going to keep feeding the MR2 oil as I'm commuting about 350 miles each weekend, damn I can't wait to get my truck back! I think the gas my truck guzzles is cheaper that the oil my MR2 is burning.
Re: damaged cam, few questions. [Re: wave] #529491 11/23/04 03:21 AM
kyle-22r Offline
no such thing as cam bearings on a 22R. the cam rides right on the head and caps.
all cams from 20R/22R/22RE motors are interchangeable, there's also a lot of performance aftermarket cams available
do you have any pictures? im having a hard time getting an idea of what you mean by pieces broken off <img src="/forums/images/graemlins/confused.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
Post deleted by little_joe [Re: wave] #529492 11/23/04 03:39 AM
Re: damaged cam, few questions. #529493 11/23/04 04:02 AM
He's fersure describing a V-6 cam....and I too believe he's talking about the thrust face on the cam.
He needs a new cam....or do they only come in pairs?
Re: damaged cam, few questions. [Re: kyle-22r] #529494 11/23/04 04:24 AM
OOP'S Offline
(95 runner 5sp w/ 3vze,Still confused!!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Definitally the thrust face, [Re: wave] #529495 11/23/04 02:00 PM
W
wave Offline OP
Thanks for the replys! Definitely the thrust face. here are a few pics
The pictures are a little dark, but you can just see the first thrust face. There are two breaks on opposite sides, each a little more than an inch.
Does the 3vze have cam bearings? I do not see any, but I keep seeing a passing reference in one of the manuals. (online autozone)
Can I just replace one, or do I need to do it in pairs?
Will replacing the cams neccesitate adjusting the valves (please god no!)
Thanks again guys!!
Anthony
Re: Definitally the thrust face, [Re: wave] #529496 11/23/04 07:04 PM
OOP'S Offline
a. Does the 3vze have cam bearings? I do not see any, but I keep seeing a passing reference in one of the manuals.(online autozone)
b. Can I just replace one, or do I need to do it in pairs?
c. Will replacing the cams neccesitate adjusting the valves (please god no!)
a. They are built into the head!!
b. I would not, replace them both!!
c. More then likely they will have to be adjusted,check them!!!
David Fritzsche
Roseville, CA
Re: EDIT....damaged cam, few questions. (Pics added a few posts down) [Re: wave] #529497 11/23/04 08:30 PM
W
wave Offline OP
I wish I knew how I did that! I was very careful when I removed the cams. I did not see the removal sequence in the book untill the 1st one was off, but I still alternated bolts. This is the only time I think it could have happened. As soon as I pulled them, I wrapped them in plastic and placed them in the truck.
Oh well.....
Thanks for the answers!!!!
Anthony
Post deleted by little_joe [Re: wave] #529498 11/23/04 08:48 PM
Re: EDIT....damaged cam, few questions. (Pics added a few posts down) #529499 11/23/04 11:31 PM
Camshafts are rather brittle-easily damaged. It might have been a bad casting and the chips happened while in service.
If ever you remove the oil pan, those pieces might be waiting there for you.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6250 MB (Peak: 0.7333 MB) Data Comp: Off Server Time: 2026-06-07 03:20:34 UTC
