Is a 4-runner the same as a pickup? #529578 11/23/04 07:38 AM
P
Packrat Offline OP
Got everyones attention didn't I?
I have a chance to pick up an '85 4-runner chasis. Had a cab fire but drive train and frame not burned.
Is the frame of a 4-runner the same as a pickup? Wheel base? Body mounts? ETC?
Beat to fit, Paint to match
Need a bigger hammer and more paint.
Did 75 Toyota (Downey 4X4 conversion Kit)
Building 88 Toyota 4X4 (7S Desert race truck)
Next 81 Toyota 4x4 (drive train conversion)
Re: Is a 4-runner the same as a pickup? [Re: Packrat] #529579 11/23/04 12:03 PM
bud r Offline
Sort of... smile
If they are of the same basic year yes. It is the same wheelbase as a shortbed pu, and the body mounts are all the same till you get to the seats. from there back, the runner mounts are different from the pu ones. Easily cut and rewelded from the old frame, if you are swapping them.
Bud R 828-572-1202
98-04 Tacoma, locked, dual cases, ready to go smile
http://www.budbuilt.com
Re: Is a 4-runner the same as a pickup? [Re: bud r] #529580 11/23/04 01:51 PM
seaflea Offline
Like bud said, it is close. The cab and front clip should bolt on, but the bed is where you will have to make adjustments. You could make it a flat bed and not worry about relocating mounts.
I hava a friend that has an 85 4runner and rolled it. He took an 86 extended cab and an old pick up bed and put them on the frame. Of course he had to cut the bed down a bit. Its now bobed and looks really good. He did nothing to the frame, ( as far as shortening it) but he did add some body mounts.
Re: Is a 4-runner the same as a pickup? [Re: seaflea] #529581 11/23/04 05:46 PM
Spacetrucking Offline
Also more affordable. Up my way pick-up's sell for twice what 4Runners get... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
'86 SR-5 Extra-cab 4 x 4, 2" BL, 33 x 12.5 x 15R M/T on 15 x 8 rockcrawlers ( 3 3/4" BS ), 22RE 5 sp , 4.88's Detroit True-Trac front, V6 open rear, 24 mm Sway-Away + Rancho 5000's, removed sway bar, no-rust south US bed, Ramsey 8000 winch
Re: Is a 4-runner the same as a pickup? [Re: Spacetrucking] #529582 11/23/04 06:03 PM
bud r Offline
But the nice rustfree doors are the same, right spacetrucking? smile
Just as soon as we get the highwaystar to smoke on the water to you... smile
Bud R 828-572-1202
Re: Is a 4-runner the same as a pickup? [Re: bud r] #529583 11/23/04 07:16 PM
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
( guess my handle reveals my growing up in the seventies ! <img src="/forums/images/graemlins/smile.gif" alt="" /> )
Re: Is a 4-runner the same as a pickup? [Re: Spacetrucking] #529584 11/23/04 08:10 PM
Red_Chili Offline
Toyota Section Staffer
Yer kiddin'!
Not here.
The 4Runner to XtraCab conversion works really nice. You end up with a bobbed SWB XtraCab. I've seen several. If I ever rolled my Runner (God FORBID!) I would give it a go.
-Bill
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6193 MB (Peak: 0.7095 MB) Data Comp: Off Server Time: 2026-11-18 22:36:28 UTC
