2.6 webber swap. #529921 11/24/04 02:25 AM
tkal Offline OP
It has been a while....
Anywho, I did a search and was not able to come up with any results. Has anyone swapped out for a webber carb? If so was there a noticeable change in power or milage?
And has anyone setup a carbed turbo? Same questions, milage and power.
'88 D-50 2.6 needs some love.
Re: 2.6 webber swap. [Re: tkal] #529922 11/24/04 02:47 AM
TobyB Offline
Don't you have to pass emissions in Puyallup?
'89 V6 4dr- '4- Doris'
Re: 2.6 webber swap. [Re: tkal] #529923 11/24/04 03:13 AM
DanWheeler Offline
of course - lots of people have done it.
I think the webber can put in more than this engine can get out. Doesn't matter though - just dont push it too far.
I think the power is bit better. Certainly the simplicity of the Weber is a plus.
Once you switch to the weber you have NO protection against water inhalation unless you buy some extra parts and do some jury-rigging.
i believe these guys do a weber turbo:
TEP Top End Racing
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: 2.6 webber swap. [Re: TobyB] #529924 11/24/04 04:30 AM
tkal Offline OP
I believe that the webber swap will pass smog in puyallup. Really the only thing that matters with the carb rigs is that it stays within smog rules for said engine.
Re: 2.6 webber swap. [Re: DanWheeler] #529925 11/24/04 04:40 AM
tkal Offline OP
I believe these guys do a weber turbo:
TEP Top End Racing
Jebus they want a lot for a turbo kit.
$2,700 for a basic turbo, manifold, ducting, and carb....
I am not looking to make this an off roading beast, I just wana give it some more omph with out having to find a Starion and turbo swap it. Get an extra...dunno 10-20 hp.
Re: 2.6 webber swap. [Re: tkal] #529926 11/24/04 05:28 AM
Those guys at TEP must smoke crack... <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> They posted a while back now about their turbo kit for the Raider. I don't think they realized how much brain trust is here. They got tooled on pretty bad for the $$$!
Re: 2.6 webber swap. [Re: MontyMcV] #529927 11/24/04 06:23 AM
This is the e-mail reply I got from TEP:
We do not have a Canadian office....The cost to do a complete rebuild and upgrade for Turbo use is $3100
+ the Turbo kit
+ Clutch assembly
Engines are assembled long blocks from Valve cover to Oil pan and front pulley to flywheel...
You will need to install the turbo kit itself when it is sent to you..That cannot be Pre-Installed..
Give us a call and we can go over details and options and get a plan for your project..
Thank you...Steve
Top-End Performance
http://www.TopEndPerformance.com
Just to rebuild my engine in Calgary it would only by 2300.00 Canadian.
Re: 2.6 webber swap. [Re: tkal] #529928 11/24/04 05:22 PM
BobShaw Offline
tkal,
I put in a weber carb, high lift cam and exhaust manifold and got a very nice 130 HP est. However, It put out 4 times the allowable emissions. Has anyone tried a carb from a Dodge van? They seem to have more power?
Actually an EFI kit should do the trick.
Bob Shaw
Re: 2.6 webber swap. [Re: tkal] #529929 11/24/04 05:44 PM
Big Blue Offline
SO what happened to the "I'm putting a V-8 in it because I can and I want to Impress my friends"
So ...where is it???
Is this Rig number 2 or.......................
Come on ...were all waiting. Pictures of the monster V-8 powered truck you built please.
Kary
1987 Mitsubishi Pajero "Modified"
The other original Mitsu brother
Northwest Trailmaster
Re: 2.6 webber swap. [Re: Big Blue] #529930 11/25/04 02:24 AM
tkal Offline OP
Heh, was kinda hoping that would be forgotten <img src="/forums/images/graemlins/smile.gif" alt="" />. I had every thing I needed, motor, tranny, most of the tools, but sadly things just did not work out. I even had a guy who could make me a driveline for free. Sadly The place I had setup to work at would not let me stay long enough to complete the project, and I could not get it licenced in a place where I could go around emissions, among a few other issues.
Every time I hit the go pedal on this thing I wish it had worked out.
But I have not been idle with the truck, I do have bucket seats in it. I normaly do not drive it, in addition to an oil leak I need to track down, something in the front end is not right. Driving on the freeway, it sways side to side way too much.
Speaking of the oil leak, it is comming from the top of the block, close to the fire wall. I ruled out the fuel pump, I am thinking either rear cam plug, or blown gasket.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6390 MB (Peak: 0.7638 MB) Data Comp: Off Server Time: 2026-11-18 03:16:55 UTC
