Gen1 LWB Body Weight
#530335
11/25/04 08:25 AM
I need to lift the body of my 1989 Gen1 LWB off the chassis, but I do not have the weight of the body. Will it be OK to hang the body by straps (recovery) through the windows, as this guy did? I saw it on Aussy forum: ![[Linked Image]](http://img.photobucket.com/albums/v474/4ePajero/AA6_2EASY.jpg)
1989 Exceed LWB 4m41 (3.2DiD TurboDiesel 5-spd Manual Tranny 2" lift 31" BFG A/T
Re: Gen1 LWB Body Weight
[Re: Boertjie]
#530336
11/25/04 02:39 PM
I wish I could tell you the anser to your weight question. But notice he has the front fenders off and a few other things off the body as well. Pluss he has some kind of device under the strap to spread the weight wider then just the strap.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
[Re: Boertjie]
#530337
11/25/04 06:28 PM
From the 89 FSM ![[Linked Image]](http://pics.montypics.com/Vic_Lee/2004-11-25/1101403191_Body_Removal.jpg) There is a copy of the 89 FSM here....... Manual
1990 Montero 2dr 3.0 Auto Lsd Front & Rear
[Re: Tag]
#530338
11/25/04 10:10 PM
I think the devices under the straps are to prevent damage to the door paint. The body must be less than 4000 lbs or only 1000 lbs per strap. Is'nt a 2" tow strap rated at 10,000 lbs? Remember, if you jerk it, the inertia load can be 3 times the static load. You should use a strap rated for at least 3000 lbs with the 4 point lift. Bob Shaw
[Re: BobShaw]
#530339
11/26/04 12:05 AM
It's probably not a good idea to run straps all the way through both sides and then try to lift with the strap(s). As the weight of the vehicle is taken up by a strap, the tendency is for the strap to press inward and could damage to the body framework through crush force. Much better to run a 4x4 through the windows, pad it where it makes contact and use an eye bolt w/fender washer and nut on each end of the 4x4, construct lead lines for 4-point lift from the eye bolts and connect the lead line(s) to the lift line(s).
Just my opinion.....
Frank
[Re: FrankR]
#530340
11/26/04 09:56 AM
Thanks for all the info, guys. I suppose that approximately 50% of the total weight lies in the body?
VicLee, Some of the files on the Russian site requires a user name and password. Can you help?
[Re: Boertjie]
#530341
11/27/04 03:07 PM
99 Montero....15mpg! Sold (so sad) 02 Jetta TDI....48mpg! 03 2500 Ram QCLB Cummins....18mpg 02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold) 01 montero limited
[Re: motero]
#530342
11/29/04 07:33 AM
Thankx for username & password
