Hanger pins #530709 11/27/04 05:41 AM
Jake Offline OP
Any suggestions for replacement hanger & shackle pins for an '82? According to the local shop they are dealer only-50 bucks can./set w/bushings.
82 4x4- tipped flipped & sunk. A "work in progress"
Re: Hanger pins [Re: Jake] #530710 11/27/04 06:04 AM
A
allochris Offline
I don't know about 82', but I just made up some wide-body shackles & planned on using 14mmx140mm Grade 10.9 Bolt for the shackle ($3-4 each) . Correct me if I'm using the wrong size bolt, for 91' pickup application. (I plan on keeping original sleeve/bushing assembly from the leaf spring & hanger.)
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: Hanger pins [Re: allochris] #530711 11/27/04 06:41 AM
4Crawler Offline
The '83 and older trucks had the funky spring hanger pins, front and rear:
They have an oversizes "head" that bolts to the side of the spring hanger, and 18mm shaft and a 14mm threaded end, necked down from the shaft. You can find them at some of the Toyota catalog places, or at a junkyard (also used on the fronts of '84-'85 pickups/4Runners).
Or better yet, hack off the stock front hanger and beef up the front end of the frame and add a new hanger that uses normal bolts (M18x120 is about what you want):
New front spring hanger
You can probably make the new hanger for less than the cost of new pins.
Re: Hanger pins [Re: 4Crawler] #530712 11/27/04 07:17 AM
OOP'S Offline
I have to agree with Roger and I want to add one other point, the stock spring hangers are weak. I have helped to repair at least three on the trail.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6018 MB (Peak: 0.6584 MB) Data Comp: Off Server Time: 2026-05-29 15:27:25 UTC
