Custom 10 leaf Deaver Springs install #534228 12/05/04 05:06 PM
E
expeditionswest Offline OP
As all of you know, the stock Tacoma rear springs suck...
I had three reasons to go with the Deaver springs:
1. Allow for an expedition load of 600-800 lbs over stock
2. Center the rear axle in the wheel well to allow my 255/85 R16 tires to fit (33.1" actual height)
3. Provide 2" of lift for additional body clearance on the trail
Well, the springs worked great, and took care of all of the above issues. The truck also rides much better now as the springs resistance through the travel range is much more constant, as opposed to the stock springs which are dual stage (overload). These springs also took care of the axle wrap, and have military wrapped ends.
DEAVER SPRING INSTALL ARTICLE
I also installed a set of longer 5100 shocks in the rear to let the springs flex a little more. I am happy with the result.
Oh, and I have also installed a set of Donahoe Coil-overs to lift the front, and will do a write up on those soon <img src="/forums/images/graemlins/wink.gif" alt="" />
Scott Brady
Jeep Wrangler Overland | J8 | Discovery I | G-Wagen | KTM 950
Re: Custom 10 leaf Deaver Springs install [Re: expeditionswest] #534229 12/06/04 08:51 AM
So Scott, do you feel like they provided you with 2 inches of llift in the rear & did you measure. This sounds like a great set-up and am willing to rid myself of my 1.5 greasable shackles if needed. Bray <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Custom 10 leaf Deaver Springs install #534230 12/06/04 03:53 PM
E
actually the lift varies a little depending on load. With only the static load in the back (things I do not remove like the 117# bumper, 90# tire, 48# jack, aux. fuel tank, etc.) it sits at about 2 3/4". When I have the aux fuel tank full and all of the other gear back there the lift comes in at a 2".
Oh, and I have a log of all of the height measurements. From stock to the current configuration.
Scott Brady
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.5907 MB (Peak: 0.6452 MB) Data Comp: Off Server Time: 2026-06-22 02:57:38 UTC
