Wrist pin bushing replacement #534259 12/05/04 08:50 PM
hazman Offline OP
Hi guys, I'm rebuilding my 87 22RE. (1)I'm looking for advice on the best way to remove the wrist pin bushing in the piston connecting rod? (2) What's the best way to install the new bushing with out buggering it up? Thanks, rj
Re: Wrist pin bushing replacement [Re: hazman] #534260 12/05/04 09:00 PM
Esquire812 Offline
Cant remember if the proper method was heating the rod ends or if just a press was used. I know it was a fairly simple process though...watched EB do it. LOL I recall him sticking the rods into this little box....
Might want to shoot EB a message and ask. That way you do it right the first time. Installing the new is done same as removing old...just backwards. <img src="/forums/images/graemlins/pfft.gif" alt="" />
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Wrist pin bushing replacement [Re: hazman] #534261 12/05/04 11:30 PM
engnbldr Offline
>>>*Removing the old bushing is done with a press and fixture. It slides right out. The process is reversed to reinstall, be sure the oil hole aligns.
A suitable hone is required to finish the ID to size, clearences are a slip fit, which means about 1/2 thousandth of an inch.
When correct the wrist pin slides freely back and forth with no vertical motion noted. Then just install in the piston and set the clips in, those should be installed with the gap, or opening, facing upwards.
Typically a job for a machine shop....*EB
*Beats the he** outa me!....*LOL**...
Re: Wrist pin bushing replacement [Re: engnbldr] #534262 12/05/04 11:47 PM
kyle-22r Offline
you say the c-clips for the piston pin should have their gaps facing the top of the piston? guess i'll give them a look before i slap them in the block <img src="/forums/images/graemlins/cheers.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Wrist pin bushing replacement [Re: hazman] #534263 12/06/04 02:42 AM
MrWiretender Offline
Like EB said... a job best left to machine shop. I had them resize rods and assemble EB's bushings, pins and pistons. For my money, it's too dang much work and expense not to use pro with proper equipment and experience at this stage.
'87 22RE
Re: Wrist pin bushing replacement [Re: MrWiretender] #534264 12/06/04 02:51 AM
OOP'S Offline
In addition, while they are at the machine shop they can check them for straightness and straighten them if necessary <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Wrist pin bushing replacement [Re: OOP'S] #534265 12/06/04 03:33 AM
hazman Offline OP
Thanks to you all! I'm going to be going to the machine shop tomorrow and have them do the job. Again thanks for your impute. rj
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6189 MB (Peak: 0.6939 MB) Data Comp: Off Server Time: 2026-06-22 02:43:50 UTC
