Wrist pin bushing replacement
#534259
12/05/04 08:50 PM
Hi guys, I'm rebuilding my 87 22RE. (1)I'm looking for advice on the best way to remove the wrist pin bushing in the piston connecting rod? (2) What's the best way to install the new bushing with out buggering it up? Thanks, rj
Re: Wrist pin bushing replacement
[Re: hazman]
#534260
12/05/04 09:00 PM
Cant remember if the proper method was heating the rod ends or if just a press was used. I know it was a fairly simple process though...watched EB do it. LOL I recall him sticking the rods into this little box....
Might want to shoot EB a message and ask. That way you do it right the first time. Installing the new is done same as removing old...just backwards. <img src="/forums/images/graemlins/pfft.gif" alt="" />
88' 4x4 *22R-EB Gen II* 87' $Runner *22R-EB Gen I* 85' Sillyca 22R-Esq  "I LIVE IN MY OWN WORLD...THEY KNOW ME WELL THERE"
[Re: hazman]
#534261
12/05/04 11:30 PM
>>>*Removing the old bushing is done with a press and fixture. It slides right out. The process is reversed to reinstall, be sure the oil hole aligns.
A suitable hone is required to finish the ID to size, clearences are a slip fit, which means about 1/2 thousandth of an inch.
When correct the wrist pin slides freely back and forth with no vertical motion noted. Then just install in the piston and set the clips in, those should be installed with the gap, or opening, facing upwards.
Typically a job for a machine shop....*EB
*Beats the he** outa me!....*LOL**...
[Re: engnbldr]
#534262
12/05/04 11:47 PM
you say the c-clips for the piston pin should have their gaps facing the top of the piston? guess i'll give them a look before i slap them in the block <img src="/forums/images/graemlins/cheers.gif" alt="" />
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: hazman]
#534263
12/06/04 02:42 AM
Like EB said... a job best left to machine shop. I had them resize rods and assemble EB's bushings, pins and pistons. For my money, it's too dang much work and expense not to use pro with proper equipment and experience at this stage.
'87 22RE
[Re: MrWiretender]
#534264
12/06/04 02:51 AM
Like EB said... a job best left to machine shop. I had them resize rods and assemble EB's bushings, pins and pistons. For my money, it's too dang much work and expense not to use pro with proper equipment and experience at this stage. In addition, while they are at the machine shop they can check them for straightness and straighten them if necessary <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
"Serenity through Sobriety"
[Re: OOP'S]
#534265
12/06/04 03:33 AM
Thanks to you all! I'm going to be going to the machine shop tomorrow and have them do the job. Again thanks for your impute. rj
