Swapping Engines! #536509 12/10/04 07:44 AM
tokyohiker Offline OP
Anyone out there ever try to put a 22RE, 3RZ-FE or 5VZ-FE engine into a 2nd generation 4Runner that originally had a 3VZ-E?
Just wondering if it's possible.
Ted 1994 4Runner
Re: Swapping Engines! [Re: tokyohiker] #536510 12/10/04 03:19 PM
You will have to do a search for this. I remember a couple of people trying the 5vz swap into a couple of different vehicles. Also, you might try searching in Google.
Off Road Solutions has a wiring kit for doing this swap here:
Off Road Solutions Accessories Page
Good luck!
Sport
Re: Swapping Engines! [Re: tokyohiker] #536511 12/10/04 08:37 PM
I swapped a 3.4L 5VZ-FE into my '93 4Runner this past spring. It's pretty straight forward. The crux of the problem is the wiring and the exhaust. For the wires, basically you have to match about 30 wires from the body to 30 wires coming from the motor. Kinda hard to figure out, but it's all there. The exhaust is just pain 'cause it's tight. Any decent exhaust shop can fabricate it up though. I did it on my garage floor and took the pipes to a shop to have them bent.....I would suggest having a shop do it though.
There is a ton of info here on 4x4 wire on how to do it. I was able to get all the info I needed here and it took about 3 or 4 weeks playin around after work and on weekends (although I took about 2 months to plan the swap).
For difficulty level, take this into account...I hadn't turned a wrench (other than basic tune-ups) in about 10 years prior to my swap.....so it's really not that hard. The only specialized tools were a motor hoist and a blowtorch to bend and weld brackets and exhaust pipes.
Re: Swapping Engines! #536512 12/12/04 03:06 AM
Wow, 93 CoRunner, that sounds pretty cool. What made you decide to do it?
Re: Swapping Engines! [Re: tokyohiker] #536513 12/12/04 05:12 AM
CORunner93 Offline
Loved the 4Runner....hated the weak motor. The 5VZ-FE is exactly what that truck was always missing. Plus I love a good project.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: Swapping Engines! [Re: CORunner93] #536514 12/12/04 05:20 AM
CORunner93 Offline
I had originally planned on rebuilding the 3.0L with all sorts of power mods....DOA heads, cams, headers, injectors....a whole list of stuff. But, in the end the 3.4L had more power than all the mods would have given and it was cheaper.....even at a cost of $4500.
The rebuild with all the extra's was about $5000. But that did include replacing all the motor sensors. My theory there was I wanted reliability and MAF and oxygen sensors and the rest of them with 162K on them don't exactly qualify as completely reliable...I was already getting O2 sensor codes. My 3.4L has 62K on it and I don't expect to have to replace anything (other than t-belt and tuneups) for another 100K.
Re: Swapping Engines! [Re: CORunner93] #536515 12/13/04 09:01 AM
Hey, anybody know anything about the 2L-TE diesel engine for 2nd generations? I think it would be cool to have diesel!
Re: Swapping Engines! [Re: tokyohiker] #536516 12/13/04 10:16 AM
kewlynx Offline
We all think it would be cool to have diesel Toys. Gotta move to Canada or elsewhere for em tho, dammit. <img src="/forums/images/graemlins/frown.gif" alt="" /> The few that are here just go and go and GO!
**ubi apis- ibi salus**
Re: Swapping Engines! [Re: kewlynx] #536517 12/14/04 05:35 PM
Somebody on Pirate gave me the following link:
toyotadieselmadness.com
They've got a lot of really cool info.
Re: Swapping Engines! [Re: tokyohiker] #536518 12/28/04 07:12 AM
thecat Offline
I am thinking of putting a 7mgte supra motor in that I have laying around.
Toyota master
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6343 MB (Peak: 0.7577 MB) Data Comp: Off Server Time: 2026-06-17 05:20:00 UTC
