Noise Diagnosis #536587 12/10/04 04:52 PM
ad54runner Offline OP
I am trying to figure out exactly what is making noise in the drivetrain of my 4Runner. I have been assuming that I need a new transmission, but after reading through many posts I don't think that is right.
First off the sound is not a whine is sounds more like if you take an electric shaver turn it on and set it on the counter. The sound is intermittent and it only happens with the clutch pedal depressed. It doesn't happen even half of the time, but all I have to do is let out the clutch either in gear or neutral and the sound goes away. Sometimes if I am sitting at a light with the clutch in and I pull it out of first and back in the sound will start until I let out the clutch.
This is on my '85 4Runner with 22RE and W56. Does anyone have any ideas?
Chris Sutton
Golden, Colorado
1985 Toyota 4Runner - Longfields, 5.29's, EZ Locker F/R, Marlin X-Over, Rancho 99012's, 35" BFG AT KO, 414K miles.
1996 FZJ80 stock with 191K miles.
1980 FJ40 stock with 85K original miles.
Re: Noise Diagnosis [Re: ad54runner] #536588 12/10/04 05:31 PM
i dont know what it is, but mine has the same thing, its more noticable at higher rpm shifts
i think its the clutch plate or something <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Noise Diagnosis [Re: ad54runner] #536589 12/10/04 06:01 PM
foxtrapper Offline
Throwout bearing most likely.
Re: Noise Diagnosis [Re: ad54runner] #536590 12/10/04 06:02 PM
G
GeriatricToy Offline
More than likely the sound your hearing is your clutch throw-out bearing. With the pedal in, the clutch fork has constant pressure on the bearing. Probably not your pilot bearing but if you have to go in there I would replace them both.
2000 Tacoma SR5 - Bone stock 'cept a little bling.
2000 Tacoma SR5 - Bone stock.
Re: Noise Diagnosis [Re: GeriatricToy] #536591 12/10/04 10:36 PM
That makes sense to me. I looked on Marlin's site for a replacement. Is a release bearing the same as a throw out bearing? I would like to go with his HD kit if everything is included:
http://www.marlincrawler.com/clutch.html
I have done one clutch before, but just put the new parts where the old parts were.
Chris Sutton
Golden, Colorado
Re: Noise Diagnosis [Re: ad54runner] #536592 12/11/04 01:36 AM
redtoy88ben Offline
throwout bearing, i put a new clutch assem. in mine with brand new throwout bearing a couple mounths ago and i have the same noise, pretty faint though, persanally im not going to worry untill the pitch changes
Re: Noise Diagnosis [Re: ad54runner] #536593 12/11/04 01:40 AM
G
Yes sir, the release bearing is an accronim for throwout bearing or visa-versa. FSM is the manual of choice but I think most manuals are pretty specific when it comes to doing a clutch job. If your talking about going in there with out a manual, yea , it can be done but you miss a few items like specific areas to apply grease and torque specifications. <img src="/forums/images/graemlins/cheers.gif" alt="" /> It's still a pretty straight foreward fix.
Re: Noise Diagnosis [Re: GeriatricToy] #536594 12/13/04 04:13 PM
Thanks guys I think I will order that HD kit from Marlin.
Chris Sutton
Golden, Colorado
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6141 MB (Peak: 0.6967 MB) Data Comp: Off Server Time: 2026-10-30 10:14:52 UTC
