Throttle Body Gasket #536806 12/11/04 03:30 AM
Don Tibbetts Offline OP
I checked out my throttle body tonight while trying to fit my Amsoil air filter (which I could not make fit, its too big) and it was quite dirty. It appeared that the gasket was a metal one. I've never seen one like that so I just wanted to be sure that I was correct. If that's the case then I don't need to worry about having a new one before I take it off and clean it out. Can someone back up this observation?
97 T100 4WD SR5 - 231K
Re: Throttle Body Gasket [Re: Don Tibbetts] #536807 12/11/04 06:08 PM
adam Offline
It is metal, but it has a crush ridge in it so that it seats properly. I'd imagine, like the crush washers on the drain plugs, that you can get a few uses out of it before it just won't seal any more. But if you notice a leak when you get done, I'd look there first (as well as at the vac lines of course).
~Adam
Re: Throttle Body Gasket [Re: adam] #536808 12/11/04 06:44 PM
Thanks. That makes sense.
Any idea what those things cost? Where's the best place to buy parts like that? Is there an internet source for Toyota parts that saves money over going to the dealer?
Re: Throttle Body Gasket [Re: Don Tibbetts] #536809 12/12/04 02:18 AM
surlynkid Offline
carroll mcmillen
gettel toyota parts
800-282-3964
tell him scott landon sent you from the t100 board
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Throttle Body Gasket [Re: surlynkid] #536810 12/13/04 08:00 AM
You can get the gaskets that are ment for the supercharger which are less restrictive from URD for $3.99URD gasket
but got lots of requests for us to make the available separately so people with normally aspirated trucks could use them for the famous "O" gasket mod. The stock gasket is "D" shaped with an obstruction that extends into the air stream resulting in a restriction. Our gaskets do not have this restriction resulting in greater flow and more power. The "O" gasket mod has become very popular with the normally aspirated crowd.
Re: Throttle Body Gasket #536811 12/15/04 04:40 AM
Thanks. Maybe I'll do the "O" gasket mod.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6099 MB (Peak: 0.6805 MB) Data Comp: Off Server Time: 2026-06-20 18:18:22 UTC
