Rodeo o2 Recommendations and Tune Up Q's #537234 12/12/04 06:47 PM
NJ_dup1 Offline OP
I need to replace the o2 sensor on my 93 3.2 rodeo, what brand have you all used and like? I understand its in front of the cat right after the y-pipe correct?
Also, i need to replace my plugs and wires. From the search I have decided to go only with ngk for 2 reasons
1) I know they wont throw codes (however i think this is only on the never 3.5l but I still want to be on the safe side)
2) Where ever I order them from I can order some spares for my quad as Im in need of some backup plugs anyways..
I need to also replace the plug wires, any recommendations or part numbers?
Also, I would like to order all this stuff off the internet, what sites do you all use to order tuneup parts?
Thanks
Nate
Nate Johnson
1993 Isuzu Rodeo 4wd - Not Much Crap
1998 Chevy Silverado 2500 - A little More Crap
2006 Suzuki Z400 - A Bit More Than A Little More Crap
2004 Yamaha Raptor 660 - Lots of Crap
Re: Rodeo o2 Recommendations and Tune Up Q's [Re: NJ_dup1] #537235 12/12/04 09:42 PM
litnin Offline
Send Jerry Lemond at jlemond@bellsouth.net a note.
He retired from Isuzu after 23 years of being their head instructor. He deals in Isuzu parts now. He sells all factory parts and sells them at better prices that you will find at any dealer. He will hook you up with the correct plugs, wires, and O2 sensors that you will need based on the production date of your truck. Some of the 3.5's used Champion plugs, but I'm not sure which units they were... he would be able to tell you everything you need to know.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Rodeo o2 Recommendations and Tune Up Q's [Re: litnin] #537236 12/13/04 04:17 AM
hunterdan Offline
Or you could head to your local parts store and buy the NGKs there, i know advance auto has them, and they should be in stock. If your looking for plugs for your atv, pull one out, head to the store with it and have them cross the number. As for O2 sensors, bosch tends to be popular and work well. I never had a problem with mine.
Dan
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5965 MB (Peak: 0.6505 MB) Data Comp: Off Server Time: 2026-05-29 23:52:28 UTC
