petroleum resistant rubber gasket
#537719
12/14/04 01:23 AM
I am trying to revive some old jerry cans and I need to replace their gaskets. Any suggestions where I can find the proper rubber, the proper type, that doesn't melt in contact with gasoline/petrol? I had some messy experiences with rubber melting and jery cans leaking all over..:( what's better betwen silicon compounds, neoprene, rubber? if anybody here manufactured their own gaskets out of something that can be easily found at the local hardware store and it worked without leaks, i would deeply appreciate the info. Obviously, there are some trustworthy companies manufacturing custom seals and gaskets out there but since I would order a very limited amount it is more feasible to go the hardware store route. thanks w.
Re: petroleum resistant rubber gasket
#537720
12/15/04 04:56 AM
Try and find a small remnant of Viton R at a local plastic supply house. We use that for fuel seals on turbine engines, should be plenty stout enough for your application.
Mike
[Re: azrain]
#537721
12/15/04 05:03 AM
Mike Thanks Mike, I should do that. Viton R. regards, w.
#537722
01/25/05 03:00 AM
Try Major's Surplus or Cheaper than Dirt. If you only need a couple, I got 10 or so several years ago and can give you a couple if you still need them (I assume you're talking about the old military "Blitz" cans). IM me. Bonus: Everything you wanted to know about Jerry Cans: http://www.rocketcityrockcrawlers.com/memberstuff/al/JerryCanPaperV1.2.pdfThanks, Al
KI4Dxx ?85 Toy 4Runner: 35x12.50 BFG MTs, manual, Kenwood 2M, 140 amp alt, 26 gal aux fuel tank '06 F-350 SRW 6.0 PSD XLT 4x4, manual, Yaesu 2m, 140 amp alt, 90 gal aux fuel tank, Air Ride air bags
[Re: Albin]
#537723
01/25/05 05:00 AM
azrain is right. look for viton gaskets,seals or o-rings. I manage a facility that handles haz-mat and we use alot of viton gaskets and seals. they handle petroleum products very well.
SAS88TOY, caged, lockered, Longfielded, etc. etc. etc. blah blah blah!!! 2005 Tundra Quadcab.
#537724
02/04/05 06:41 PM
I am trying to revive some old jerry cans and I need to replace their gaskets. Any suggestions where I can find the proper rubber, the proper type, that doesn't melt in contact with gasoline/petrol? I had some messy experiences with rubber melting and jery cans leaking all over..:( what's better betwen silicon compounds, neoprene, rubber? if anybody here manufactured their own gaskets out of something that can be easily found at the local hardware store and it worked without leaks, i would deeply appreciate the info. Obviously, there are some trustworthy companies manufacturing custom seals and gaskets out there but since I would order a very limited amount it is more feasible to go the hardware store route. thanks w. So, didja get fixed up?
[Re: Albin]
#537725
02/04/05 06:55 PM
