flasher relay for led lights #48510 03/12/03 11:29 PM
DerekM Offline OP
Searched here and on <img border="0" alt="[Pirate]" title="" src="graemlins/bppirate.gif" /> , but didn't find specific answers. I got 2" recessed led's for the new winch bumper and , of course, the stock flasher relay doesn't get along with them. As I understand I have 2 options.
1)wire resistors in parallel w/ the led's to create a bit more draw on the relay. problem- I have no idea which resistors I would need.
2)Get a relay compatible with led's. One with the same connectors as stock would be preferred. "heavy-duty" realays were referred to by some, but that's not very specific. Also mentioned were electronic as opposed to mechanical(bi-metal) flasher relays which don't care what the current draw is, and again a toyota compatible unit would be preferred.
Anybody been here before with specific info? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Thanks all for the help!
Re: flasher relay for led lights #48511 03/13/03 02:45 AM
TNToy Offline
If you want to go the resistor route, go down to radio shack and grab a potentiometer and wire it in there. A potentiometer is basically a variable resistor.
GEt it so it blinks the rate you want, take a multi-meter and measure the resistance, and hard wire the appropraite-sized resistor(s) in there.
Re: flasher relay for led lights #48512 03/13/03 04:10 AM
Frankenyota Offline
You'll have to shoot through the old bulbs with a multimeter to see how many ohms of resistance they have. Get an equivalent resistor but keep in mind it has to dissapate a great deal of heat energy, I smoked a little 1 watt res. so you better look for a higher wattage one. I eventually found some bulbs to use so I abandoned the resistor idea. The flasher is some goofy toyota only crap so I have no idea where to get an electronic or heavy duty one, sorry I wish I knew.
1986 4X4, 1991 22RE, 5.71 gears,ARB Rear, aux fuel tank, 3mm O/S TB/intake, engnbldr cam, LCE header, magnaflow w/2.25 exh. custom 4 color paint job :-P 33X12.5 Goodyear MT/Rs
Re: flasher relay for led lights #48513 03/13/03 02:18 PM
fourwd1 Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Frankenyota:
<strong>The flasher is some goofy toyota only crap so I have no idea where to get an electronic or heavy duty one, sorry I wish I knew.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">The Toyota flasher is electronic instead of the old 2 terminal bi-metal electro-mechanical type, and should be more tolerant of load variations. You can use an old style 2 terminal flasher in it's place, but for your application it wouldn't work either.
You could increase current draw by replacing the incandescent bulbs in the rear turn signals with higher wattage ones (halogen for instance).
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: flasher relay for led lights #48514 03/13/03 08:13 PM
DerekM Offline OP
Thanks guys, great ideas-
-so for the resistors I should be able to ask for a wattage & resistance equal to that of the bulb I've replaced? Makes sense.
I will probably get the info and let the radio shed guy figure it out.
I may try replacing my flasher relay w/ a new one (may be newer technology) because mine is original as far as I know (it's louder than sin when flashing).
I'm painting the bumper tonight and the signals are all thats left to do. I hope the old bellvue is ready for a workout! I'll try and post pics when it's done. I know there aren't many upright warns on the front of mini trucks, and custom is your only choice. Thanks-
edit: lets try this....
<img src="http://pics.montypics.com/derekm/2003-03-13/winch_bumper-122834.jpg" alt=" - " />
<small>[ March 13, 2003, 02:30 PM: Message edited by: DerekM ]</small>
PHP: 7.4.33 Page Time: 0.010s Queries: 14 (0.007s) Memory: 0.6099 MB (Peak: 0.6751 MB) Data Comp: Off Server Time: 2026-11-17 06:26:07 UTC
