8 bolt to 10 bolt conversion #538709 12/15/04 09:21 PM
TrooperMagnum Offline OP
Thanks to Joe Hope <img src="/forums/images/graemlins/cheers.gif" alt="" />, I've got my 10 bolt all bolted in and the old 8 bolt scattered about the garage. (Now I have the rare 10bolt/10bolt Trooper!)
Everything bolts right in to '87 Trooper....except for the drive shaft. The 8 bolt shaft is too small to bolt to the 10 bolt flange.
Has anyone run into this problem? What is the fix?
<img src="/forums/images/graemlins/confused.gif" alt="" />
I'm gonna go to the junk yard tonight to get a 10 bolt shaft and compare the two shafts. Worst case is I cut the two shafts apart and make a custom shaft.
Thanks ya'll.
Karl <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Why?....Because they dared me to!!!
Re: 8 bolt to 10 bolt conversion [Re: TrooperMagnum] #538710 12/15/04 09:30 PM
4WDJOE Offline
Yeah Karl the u pull it idea may just be a bolt up solution. <img src="/forums/images/graemlins/cheers.gif" alt="" />
97 Rodeo
Re: 8 bolt to 10 bolt conversion [Re: 4WDJOE] #538711 12/17/04 03:04 AM
OK...Haven't had time to go to the junk yard.
How many splines are on the front shaft (at the slip joint) of a 10 bolt? What is the diameter?
Anybody know?
Thanks,
Karl
<img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: 8 bolt to 10 bolt conversion [Re: TrooperMagnum] #538712 12/17/04 04:37 PM
4WDJOE Offline
17 splines and about 1"1/4 in diameter(sorry no metric conversion, I'm numericaly challenged <img src="/forums/images/graemlins/lol.gif" alt="" />)
Karl I'm going to the Foster U Pull It today to get some wiring, do you want me to pick you up a 10 bolt driveline?
97 Rodeo
Re: 8 bolt to 10 bolt conversion [Re: 4WDJOE] #538713 12/19/04 02:32 AM
.....Karl I'm going to the Foster U Pull It today to get some wiring, do you want me to pick you up a 10 bolt driveline?
I just read this.....I hope you didn't buy anything. I'll buy it if you did. Thanks man.
I went to the u-pull it and grabbed a shaft from an '89.
Thankfully the slip joint splines matched up, but the shaft is too long.
I cut the shaft to fit and will be welding it up tonight or tomorrow. Once the shaft is bolted in, then I'm all done! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Joe, I can't thank you enough for your help with parts. You Rock! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Karl
PHP: 7.4.33 Page Time: 0.024s Queries: 15 (0.019s) Memory: 0.6063 MB (Peak: 0.6714 MB) Data Comp: Off Server Time: 2026-11-17 06:13:18 UTC
