gas guage #538724 12/15/04 10:14 PM
1991monterols Offline OP
My gas guage does not go all the way to the top, so i know it is running low, is there a way to fix it?
thanks nate
1991 Montero LS 5sp with 32s on black 15x8, snorkle, roof rack, 9000lb milemarker, cb, 4 hella lights sold
1991 Montero RS Auto on 35s, 2in BL, hella lights, cb, roof rack blown headgasket
Re: gas guage [Re: 1991monterols] #538725 12/15/04 10:44 PM
Does it then take a while before it starts to drop, waiting for the gas to be consumed down to the level the needle is?
Don't know on yours, but I've bought a Gen II sending unit for something like $60 maybe, and a Gen I 4-cyl for like $35.
Re: gas guage [Re: 1991monterols] #538726 12/15/04 10:48 PM
BobShaw Offline
Either the float is sinking or something changed the resistance. I think the resistance increases from full to empty. Mine gage reads zero until I run thru deep water, then it reads until it dries. I must have a bad ground (infinite resistance) between the float level assy and the tank.
Bob Shaw
Re: gas guage [Re: 1991monterols] #538727 12/16/04 12:30 AM
i got a new sending unit, so that not the problem, can i get a new guage
nate
Re: gas guage [Re: 1991monterols] #538728 12/16/04 01:44 AM
Well, probably is the gauge then. Are you sure you have a good connection to the new sender? I'll bet a corroded connector on the harness side might cause some trouble. As for the gauge itself, I would think you could find one readily at the yards. Might have to buy the whole gauge panel though.
Re: gas guage [Re: MontyMcV] #538729 12/16/04 05:02 AM
52degrees Offline
A connector that has higher than normal resistance but is otherwise OK can cause the guage to read lower than normal at all times. That is if it is the same as GM (and most brands are). Take the gauge wires at the tank and disconnect them (if you can, I've never looked at it) then cross them. Make sure your crossing the correct wires first. The gauge should peg full. This will tell you nothing, but you'll know the gauge is capable of reading full if all else fails.
If someone out there knows I am wrong about this, speak up. This works on 90% of cars I've seen so I'm just assuming it'll work on a Mitsu.
Clay
KG6VNX
Re: gas guage [Re: 52degrees] #538730 12/16/04 05:33 PM
There is a voltage regulator on the back of the pc board for the gauges. It limits gauge voltage to 7v, and serves the temp and fuel gauges. If it loses it's ground, it allows full voltage to the gauges, permanently warping the bimetals inside, causing a low reading on BOTH gauges. The ground is a screw on the pc board, and is shown in the FSM. The only cure is to swap out the gauges, and tighten the ground. With a normal gauge and stock thermostat, your temp gauge should be just short of half scale at normal op temps.
Re: gas guage [Re: 52degrees] #538731 12/16/04 06:50 PM
BobShaw Offline
ClayV
My Raider has only one wire from the gage to the tank. The 2nd wire is the ground?
Bob Shaw
Re: gas guage [Re: BobShaw] #538732 12/17/04 03:21 AM
Ground the single wire and the gauge should go full scale - don't leave it grounded long.
Here's the 89 manual #'s:
Fuel gauge resistance value (ohms)
terminals 1 (power) & 2 (gauge) 55
terminals 2 & 3 (gnd) 165
Fuel gauge unit resistance value (ohms)
Float point ôFö: 1-5
Float point "Eö: 103-117
Re: gas guage [Re: 52degrees] #538733 12/17/04 06:39 AM
52degrees Offline
Clay
Yep, I wasa mistaken. Sorry to add confusion to what was a very good thread.
Like I said, my thought were based on GM experience, not Mitsubishi.
The really cool thing is it got everybody talking about the right stuff and being more direct about how this thing works. I think that's great.
I didn't know Mitsu only used one wire for the fuel sender. That makes it a ground from the gauge and the sender provides varying resistance via the float to provide more current to ground or less. Pretty cool. and I bet it works really well as apposed to anything GM has put out in recent memory (cough, since '95, cough cough). <img src="/forums/images/graemlins/lol.gif" alt="" />
Clay
KG6VNX
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6344 MB (Peak: 0.7428 MB) Data Comp: Off Server Time: 2026-06-21 12:16:53 UTC
