Max life Oil? for the high milage T or just Plain old oil? #539049 12/16/04 02:56 PM
spotshooter Offline OP
Hey do you guy's use premium Motor oil in your T's or just plain old oil.
Max life valvoline cost's 2X as much as just plain old.
4.49 a quart vs. 2.29?
What do you guy's use.
Spot
Spot
2007 Tacoma Off road Double Cab
VSC, DAC, Side air bags, Snugtop, tinted front windows, Westin Platinum steps, weathertech mats, coverking seat covers, bed mat, tow package, dimming mirror.
Re: Max life Oil? for the high milage T or just Plain old oil? [Re: spotshooter] #539050 12/16/04 03:52 PM
JohnF Offline
Mobile 1 synthetic is about $20 for a 5 quart container at Walmart. I've been using it since 15k miles, changing oil at 5000 mile intervals. Currently, I have 185k on my truck. It runs great, and I never need to add oil between changes.
MaxLife is available in Synthetic, it's $5 per quart at Checker Auto.
From Valvoline's website:
Unlike regular synthetic oil, MaxLife Synthetic is advanced synthetic PLUS special additives to fight the effects of aging. If you use synthetic motor oil in your engine and it has 75,000 miles or more, then MaxLife Synthetic is right for you!
MaxLife Synthetic helps extend the life of engines by providing:
Special seal conditioners to help keep engines cleaner and reduce oil consumption
Additional anti-wear additives to reduce friction and help prevent future wear
Extra cleaning agents to help reduce deposits, sludge and varnish formation
Advanced thermal stability to help reduce oil burn-off and maximize power output
Re: Max life Oil? for the high milage T or just Plain old oil? [Re: spotshooter] #539051 12/16/04 05:10 PM
Brian_M Offline
I use Mobil 1 15w50 (usually pick it up at a yearly 2 for 1 sale, works out to be about $2.50/quart) and run it for between 10 and 15k miles. Every oil analysis I've done on this stuff over the years shows that at 10k miles the oil is at 80% or better (meaning it has a LOT of life left). I've only done a couple at 15k miles, but figgure the filter needs changing by then anyway (I always change the oil/filter once a year ~ if I make any mileage or not).
I've only got 16k miles on my T, with an oil change at 2k, then again at 7k (after moving, I figgured I taxed the engine pretty badly and it deserved fresh fluids).. I'll probably send the oil off to be checked at the 10k mile mark after the holidays. This thing is still at the full mark at 9k miles too... first 4-wheeled vehicle that's ever done that for me. smile
There is ZERO need to change synthetic oil any sooner than 10k miles... I've seen this time and time again. I'm 90% certain that 15k miles is safe and reasonable and willing to try going 20k miles sometime just to see what the oil analysis says.
Cheers,
Brian M
'97 T100 SR5 4x4, with Buckets
Re: Max life Oil? for the high milage T or just Plain old oil? [Re: Brian_M] #539052 12/16/04 05:33 PM
mikem Offline
Whoa! Are you kidding?
1995 T100 SR5 XCab 2WD Auto
Re: Max life Oil? for the high milage T or just Plain old oil? [Re: mikem] #539053 12/16/04 07:35 PM
Brian_M Offline
*I*.. me, myself have driven 16k miles (since April, 04).. the trucks at 131k
Cheers,
Brian M
Re: Max life Oil? for the high milage T or just Plain old oil? [Re: spotshooter] #539054 12/16/04 07:39 PM
Mobile 1 10W-30 changed every 5K. I understand you can go longer between changes, but for 20 bucks in oil and 4 bucks for an OEM filter, pretty cheap peace of mind IMHO.
Re: Max life Oil? for the high milage T or just Plain old oil? #539055 12/17/04 01:20 PM
So is moving to Syn oil like mobile one somthing I should or can do at this point with 135k on the beast?
Spot
Spot
Re: Max life Oil? for the high milage T or just Plain old oil? [Re: spotshooter] #539056 12/17/04 04:26 PM
Brian_M Offline
It won't Hurt anything, but you may find that leaks develop, or oil consumption goes up (maybe, I doubt it if the T had even basic care). If that happens, just switch back to dino oil (or track down the leaks and fix them.. most people don't take that route though).
Cheers,
Brian M
Re: Max life Oil? for the high milage T or just Plain old oil? [Re: mikem] #539057 12/17/04 05:20 PM
cookiemech Offline
I bought my 1993 T100 4 x 4 new and it only has a TOTAL of 14k on it right now. Never in the salt. Bought a new Tundra about six weeks ago, so the T100 may never be driven again.
1993 T100 4 x 4 longbed
2005 Tundra 4 x 4 longbed
Re: Max life Oil? for the high milage T or just Plain old oil? [Re: Brian_M] #539058 12/18/04 01:04 AM
hunterdan Offline
15W-50 seems like an extremely heavy oil to be running in a gas motor. That 50 weight may be too thick. If the manufacturer calls for a certain oil, 5W-30, 5w-20 etc, you better stick to what it calls for, otherwise the oil wont go where it should be, and if its too thin, it wont support the load the bearings place on it. You may want to read up on the design on bearings and such. Theres a whole process that involves designing the bearing for a certain load, but then you must calculate the right oil to support that load, as the bearings should make little to no metal to metal contact. The thicker weight oil supports the load better, but are you sure its getting to where it should be? Im sure the thicker oil holds up longer, but the first few thousand miles, that oil is probably not getting to where it should be. IMO theres no need to run any oil thicker than 10w-30 in newer motors if there is no sign of oil being burned. The tolerances are so tight, the thick oil may not be getting to where it should. This is particularly true on import motors, toyota, honda, isuzu, etc. There was a point when I thought the heavier oil was better for my truck, but then I sat in class and learned that heavier oil is not always good when things are still within spec.
Dan
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6388 MB (Peak: 0.7633 MB) Data Comp: Off Server Time: 2026-06-23 00:45:20 UTC
