Change in Fuel Economy - Need Advice #539092 12/16/04 06:13 PM
4barrel Offline OP
Hello All -
I am experiencing a change in my average fuel economy over the past couple months on my '99 V6 4WD (80K). I was getting about 19-20 on the highway, 17-18 around town. I've noted about a 15% drop in economy, notably on the highway.
I've looked at prior postings, and am hoping for help to narrow down the potential causes:
TSB '99 Fuel Gauge Issue - I bought my Runner with 40K two years ago - how can I find out if the prior owner had the TSB performed? (my gauge does bounce around a bit).
New Tires - This summer, went with Bridgestone Duelers (265/70R), whereas I had 265/75s previously. My intuition tells me there really shouldn't be much of a difference, but can anyone confirm this?
Tuning - About a month ago, thinking this was part of the problem, I cleaned the MAF, throttle body, etc (still very clean from the last time I had done this), and cleaned/re-oiled my Amsoil filter. Additionally, my plugs (OEM) are 1 year old, and look nice and clean (I had expected them to be fouled up). I also reset the EFI fuse. No improvement.
One thing I didn't do was change the fuel filter, and OK, I embarrassed to ask, but where the heck is it?? Should I replace at 80K miles? Could this be the cause?
Thanks in advance for any guidance, or other theories.
1999 SR5 V6 4WD
Addcos, Bilsteins, Detroit Truetrac, Amsoil, etc...
Re: Change in Fuel Economy - Need Advice [Re: 4barrel] #539093 12/16/04 06:38 PM
I am experiencing the same problem as of last month. it could be the "winter gas".
as a matter of fact I replaced the OEM tires with the same 265/70R REVO's before I noticed the fuel consumption increase.
I also cleaned the MAF, replaced the AMSOIL, reset the EFI and I will try to replace the plugs tomorrow.
the fuel filter is located right about underneath your butt, you can't miss it if you look under hte car.
w.
Re: Change in Fuel Economy - Need Advice [Re: 4barrel] #539094 12/16/04 08:25 PM
engnbldr Offline
>>>*Every single one of my vehicles dropped about 12-15% this Fall, just like they do every Fall.
Oxygenated fuels, of course....Could be as simple as that.. Check the pumps where you buy fuel, see if they says "Contains Alcohol"...*EB
*Beats the he** outa me!....*LOL**...
Re: Change in Fuel Economy - Need Advice [Re: engnbldr] #539095 12/18/04 12:53 AM
4barrel Offline OP
I checked the pump at my latest tank up - sticker noted 10% ethanol content. Could this be the sole cause of the drop?
1999 SR5 V6 4WD
Re: Change in Fuel Economy - Need Advice [Re: 4barrel] #539096 12/18/04 01:15 AM
E
esun127 Offline
Since you got smaller tires, your fuel economy should go up. 10-15% lower than 19-20 highway is about what I get on my SC'd runner.
The difference in fuel is an interesting theory... I'd like to see what other people say about that.
Re: Change in Fuel Economy - Need Advice [Re: esun127] #539097 12/18/04 02:12 AM
4barrel Offline OP
regarding the tires - I figured the smaller tires would throw off the odometer, showing less miles traveled than actual. however, I checked that on a recent trip of known distance, and I am definitely using more fuel than on prior trips.
1999 SR5 V6 4WD
Re: Change in Fuel Economy - Need Advice [Re: 4barrel] #539098 12/18/04 02:48 AM
dsalvetti Offline
Hey guys... I'm new to the board, but trying to get caught up as quickly as possible. I bought a '98 SR5, V6, 5-speed in November and have used this site to answer a lot of questions.
I have not heard of resetting the EFI fuse... can someone explain this? What are the symptoms? By the way, I'm averaging about 17mpg for my first couple of tanks.
Thanks a lot!
Dave
'98 4Runner SR5, 3.4L, 5-Speed, 4WD >>K&N, ISR, TRD Clutch, 265/75R16 Yokohoma Geolandar AT+II's, OME (880/N91SC, 906/N86C)>> SOLD to pay bills.
Re: Change in Fuel Economy - Need Advice [Re: dsalvetti] #539099 12/23/04 02:33 AM
4barrel Offline OP
Hi, dsalvetti. I just saw your post -
The EFI fuse is located in the engine compartment fuse box - you can't miss it. By resetting - I simply mean that I pulled the fuse for a half a minute and reseated it - I've done this before to help clear OBD II trouble codes. Probably not really applicable in my case, but I did it anyway.
I threw in some valvoline fuel system cleaner, and have slowed down a bit <img src="/forums/images/graemlins/evil.gif" alt="" /> on my last long distance drive - MPG a touch higher 17.6 - but still not where I was at before. Looking to change the fuel filter next. Hopefully it's just the winter gas.
1999 SR5 V6 4WD
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6251 MB (Peak: 0.7200 MB) Data Comp: Off Server Time: 2026-06-21 12:09:38 UTC
