Power steering pump bleeding?!!! #540608 12/20/04 05:37 AM
W
wave Offline OP
Wow, Finally got the heads back on and the truck back together. The truck cranked right up and seems to be runnig good so far! The latest though is that I had the pump hanging and think all the power steering fluid leaked out. The truck is a 95 runner w/ the 3.0 and anti lock brakes. The service manual lost me. The diirections have me bleeding the brakes and then hooking up some king of computer to re-set things.
Anyone have any ideas on this?
I am hoping someone has a shortcut!
Anthony
Re: Power steering pump bleeding?!!! [Re: wave] #540609 12/20/04 06:05 AM
OOP'S Offline
The pump and system will usually bleed itself, but you may need to bleed the steering box. Some of them have a bleeder on the top cap that is held on with four bolts and has the adjusting screw in the middle and you just crack it open with the engine running. You can use a container filled with a bit of fluid and a hose from the bleeder into the container. If it does not have the bleeder then you have to loosen the nut that is on the adjuster and let it bleed until it just has fluid coming out. Then holding the adjusting screw with a screwdriver, tighten the nut. What I would do first is to jack up the front-end with the wheels off the ground, set it on jack stands making sure the tires are off the ground. Make sure the reservoir is full of ATF (you do use ATF and not power steering fluid I hope). Start it up and cycle the steering lock to lock about five times. Shut it down and check the reservoir, if it is foamy, let it sit for about half an hour, replenish the reservoir and repeat until not foamy.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Power steering pump bleeding?!!! [Re: OOP'S] #540610 12/20/04 06:20 AM
4Crawler Offline
Usually pretty much as described above. Back and forth a few times w/ engine off (tires off the ground) then a few times back and forth with the engine idling.
There is a very detailed writeup on...cally for Toyota but has some good tips.
Re: Power steering pump bleeding?!!! [Re: wave] #540611 12/20/04 12:15 PM
kewlynx Offline
To add, Toyota spec is Dextron II or III. The seals will appreciate it.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6029 MB (Peak: 0.6600 MB) Data Comp: Off Server Time: 2026-06-20 20:14:03 UTC
