Front Drive shaft for SAS #541627 12/22/04 05:06 AM
J94_4runner Offline OP
Ok guys, almost there... i got the custom brake lines made today and bled the system. only thing i'm missing is my steering rod and a driveshaft. I sold my stock front Dshaft a while back to fund this SAS <img src="/forums/images/graemlins/drunk.gif" alt="" /> So should I get a Toyota IFS shaft and have it modifided, or just take it the local drivetrain places and have them make a complete custom one? will a Tacoma V6 front Drive shaft work for mod'n? what's the best plan of attack here? on the axle i have a yoke that takes U bolts (1330? U joint I think) and on the Tcase I have the stock Yota flange. I have the V6 set up.
www.celicasupra.com
Re: Front Drive shaft for SAS [Re: J94_4runner] #541628 12/22/04 05:42 AM
bkg Offline
Call Jesse @ high angle driveline...
www.highangledriveline.com
Brian K. Gallus
Re: Front Drive shaft for SAS [Re: bkg] #541629 12/22/04 09:25 PM
9
94krawler Offline
yeah call jesse.he made mine up.thought the cv was going to be what was needed but he said no single joint will work better for me.use the cv for rear shaft.i have had my front driveline through some nasty stuff and no damage and runs smooth.i did have to use a non cv flange though on my t-case.
94 toy truggy rolling on tons
>>>>>>>>www.Rightcoast4x4.com<<<<<<<<
Rockcrawling for the eastcoast.
Re: Front Drive shaft for SAS [Re: 94krawler] #541630 12/23/04 04:28 AM
TexJeff87 Offline
How much $$$ did that set you back? I'm in the same situation....but I still have my donor front shaft as well as the IFS one.
JT
If Mad Max had a 4runner...
Re: Front Drive shaft for SAS [Re: TexJeff87] #541631 12/23/04 06:40 AM
9
94krawler Offline
i dont remember.call jesse and he will give you a price.alot of times his machine picks up.leave a message he will call you back.BTW i got the moster thick tubing on mine.
Re: Front Drive shaft for SAS [Re: 94krawler] #541632 12/24/04 07:42 PM
seafarinman Offline
make a square shaft-cheap and works great
Rome
1994 Toyota 4x4 SAS pickup/2RZ/R151F=244:1!
1987 Toyota SAS pickup 37" MTR's
1993 Nissan NX2000 Dropped pocket rocket
Re: Front Drive shaft for SAS [Re: TexJeff87] #541633 12/24/04 08:06 PM
OOP'S Offline
How much $$$ did that set you back? I'm in the same situation....but I still have my donor front shaft as well as the IFS one.JT
I think about 275-300 dollars. It would be best to call Jessie and give him the details of what you need!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Front Drive shaft for SAS [Re: OOP'S] #541634 12/24/04 10:55 PM
half_fast Offline
a self-made square shaft is economical... but I wouldnt use in high torque situation. Id say only lighter vehicles with under 100 hp and close to stock tires/gearing. Seen a lot of them used successfuly on Suzuki's...
Michael J. Carsner proud driver of "Aint Pretty"
37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor.
MUD!!! Its whats for dinner!!
Re: Front Drive shaft for SAS [Re: half_fast] #541635 12/24/04 11:01 PM
Adam F Offline
Why wouldnt you? I'd say, if properly welded, it would be stronger than a factory round tube drive shaft. You make it out of 1/4" square tube. It's beefy as hell.
Only bad part is the vibrations and clanking you get. I can spin mine up to about 35 MPH before it started to vibe out of control.
97 4R, stock, daily driver
Re: Front Drive shaft for SAS [Re: Adam F] #541636 12/25/04 03:20 AM
seafarinman Offline
Yeah the one on my 87 is pretty noisy, but I only use it in 4WD on the trail anyhow.
Rome
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6403 MB (Peak: 0.7596 MB) Data Comp: Off Server Time: 2026-06-24 12:10:16 UTC
