Probably a dumb question, but I need help.... #542921 12/27/04 10:26 AM
N
nigeltufnel Offline OP
Hello all,
I have a 94 xtracab pickup. I am building an enclosure for an 8" sub. I am going to put it in the storage compartment in the back-seat bench. I haven't got the sub yet. The compartment is only 8.75" wide. Here's my question: is this wide enough to fit the sub? I know it probably varies from sub to sub, but about how wide is the entire 8" sub? Is it the actual moving speaker that is 8", or is the entire unit, plastic mounting ring and all, 8" wide? Hope this makes sense. Any input is greatly appreciated. Thanks and happy holidays!
Re: Probably a dumb question, but I need help.... [Re: nigeltufnel] #542922 12/27/04 03:01 PM
Adam F Offline
You can't just put a sub in there without an enclosure (box). It will sound like complete garbage.
97 4R, stock, daily driver
Re: Probably a dumb question, but I need help.... [Re: Adam F] #542923 12/27/04 03:50 PM
half_fast Offline
my 12's are 12' cone only..not including the metal frame
Michael J. Carsner proud driver of "Aint Pretty"
37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor.
MUD!!! Its whats for dinner!!
Re: Probably a dumb question, but I need help.... [Re: nigeltufnel] #542924 12/27/04 06:49 PM
willzrunna96 Offline
you have to make a compete box in there BUT you want to get your internal volume of that box as close to one as you cen get it or iwhatever they sub you want reccomends. A seald box always sounds best but if it has to be really small you might want to port it to comensate for small volume. You wont be able to get a really good high spl sub becuase mose of them require a large mounting depth. if you want a spl sub with only a 4 inch mounting depth get a audiobahn pro compression. also dont get a 8" subn go for a 10
Re: Probably a dumb question, but I need help.... [Re: willzrunna96] #542925 12/27/04 06:50 PM
an entire 8 inch sub is uslay 8 to 9 inches long the cirlce you will have to cut is probaly 7 inches diamter BUT this varies on sub
Re: Probably a dumb question, but I need help.... [Re: Adam F] #542926 12/27/04 08:01 PM
N
Hello all,
I have a 94 xtracab pickup. I am building an enclosure for an 8" sub.........
Re: Probably a dumb question, but I need help.... [Re: willzrunna96] #542927 12/27/04 08:06 PM
N
Thanks for the input. It is greatly appreciated! And correct me if I'm wrong, but I thought a ported enclosure was supposed to be bigger than a sealed one.........And I'm with you, I'd much rather go for a 10", but the place I'm building the box for is only 8.75" wide.....
So my box will be 8.5" wide. Will it be ok if the sub mounting ring/frame overhangs that a little bit? Thanks again!
Re: Probably a dumb question, but I need help.... [Re: half_fast] #542928 12/27/04 08:08 PM
N
Thanks for the reply. So is the metal frame about 1" wide or so?
Re: Probably a dumb question, but I need help.... [Re: nigeltufnel] #542929 12/27/04 10:50 PM
4
4xGeek Offline
It all depends on the speaker manufacturer... My 8" Kicker's have 7/16" lip all the way around, but my roommates Fosgate has 1/2". You need to decide on a speaker *before* you start to plan a box. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6285 MB (Peak: 0.7320 MB) Data Comp: Off Server Time: 2026-10-24 02:37:29 UTC
