Welding & Electronics #543008 12/27/04 06:41 PM
RT1 Offline OP
I have to weld some reinforcement on a back frame that's rusting out. I don't want to smoke the electronics on my 2.6mpfi in the process with my arc welder. Any tips on isolating the electrical system so I still have a working vehicle when I'm done or is it a non-issue if I keep the ground close to the site of the welding?
'89 P'up, 2.6 I-Tec, 488,000 miles and done... gone to the great beyond
Re: Welding & Electronics [Re: RT1] #543009 12/27/04 07:30 PM
mlclark Offline
Isuzu Moderator
Pull the negative cable off the battery and as you said, keep the ground lead close to where you are welding. If you are still worried, disconnect the ECU.
Good Luck,
Michael
Re: Welding & Electronics [Re: mlclark] #543010 12/27/04 08:36 PM
litnin Offline
Good Luck,
Michael
Perfect advise!
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Welding & Electronics [Re: mlclark] #543011 01/04/05 12:23 AM
RT1 Offline OP
Thanks. I figured it was that easy, but never hurts to make sure.
Re: Welding & Electronics [Re: RT1] #543012 01/04/05 02:15 AM
I never disconnect my battery or anything, I probably should but IÆve never had a problem. I wouldnÆt worry about it.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6032 MB (Peak: 0.6673 MB) Data Comp: Off Server Time: 2026-06-10 00:08:19 UTC
