Re: Mitsubishi 4x4 Frequently Asked Questions for New Members
[Re: DaphneD]
#543790
12/31/04 06:43 PM
I have the bouncy seat. I do not have the headlight washers or LSD. But mine is a Raider not a montero. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
[Re: pmontero]
#543791
01/01/05 11:51 PM
Wow.. <img src="/forums/images/graemlins/kewl.gif" alt="" /> This is great. Keep it coming. I was just about to post a question: But not any more because I found the answer within these posts.
1987 DODGE RAIDER 4X4, 2.6 LITTER, 5 SPEED MANUAL MODS+PARTS:
[Re: lu0902]
#543792
01/13/05 12:15 AM
GenI Recommended Regular Scheduled Maintenance (as taken from the '89 FSM) with some changes and additions:
Change Engine Oil = 7,500mi (12,000k) or 12mos *Replace oil pan drain plug gasket at every oil change Replace Engine Oil Filter = 15,000mi (24,000k) or 12mos Change ATF = 30,000mi (48,000k) *Replace ATF oil pan drain plug gasket at every oil change Check M/T Gear Oil = 30,000mi (48,000k) Check T-Case Gear Oil = 30,000 (48,000k) Check Fr Differential Gear Oil = 30,000mi (48,000k) Check Rr Open Differential Gear Oil = 30,000mi (48,000k) Change Rr LSD Gear Oil = 30,000 (48,000k) Replace Brake Fluid = 30,000mi (48,000k) or 2yrs Change Engine Coolant = 30,000mi (48,000k) or 2yrs Grease UCA & LCA Ball Joints = 15,000mi (24,000k) or 12mos Grease UCA shaft = 15,000 (24,000k) or 12mos Grease Steering Linkage = 15,000mi (24,000k) or 12mos Grease Propeller Shaft U-Joints = 30,000mi (48,000k) or 2yrs Repack Fr Wheel Bearings = 30,000mi (48,000k) or 2yrs Replace Air Filter = 30,000mi (48,000k) Clean PCV Valve = 80,000mi (128,000k) or 5yrs Replace Spark Plugs = 30,000mi (48,000k) Replace Ignition Cables = 60,000mi (96,000k) Check Distributor Cap = 60,000mi (96,000k) or 5yrs Check Distributor Rotor = 60,000mi (96,000k) or 5yrs Replace Drive Belts = 30,000mi (48,000k) Replace Timing Belt = 60,000mi (96,000k) Replace 02 Sensor = 80,000mi (128,000k) Replace Fuel Filter = 50,000mi (80,000k) or 5yrs Replace Charcoal Canister = 100,000mi (160,000k) Inspect Fr Disc Brake Pads for wear = 15,000mi (24,000k) or 12mos Inspect Fr Brake Calipers = 30,000mi (48,000k) or 2yrs Inspect Rr Drum Brake Shoes for wear = 30,000mi (48,000k) or 2yrs Inspect Rr Drum Brake Cylinders = 30,000mi (48,000k) or 2yrs Inspect Brake Hoses = 30,000mi (48,000k) or 2yrs
[Re: pmontero]
#543793
02/10/05 07:06 PM
3.0L V6 Crank pulley
Q: STOP! Read the answer below before you even ask this question. A: The crank bolt on ALL Mitsubishi 3.0L V6 engines is a recall item. This is mentioned several times in the archives. Do a search and you will come up with seemingly endless results of people who have had their crank bolt snap and things go haywire. The old bolt was prone to undertorquing and failure. You will need to replace it.
Q: What's that you ask? Do I really have to worry about this? A: If you have a Mitsubishi 3.0L V6 engine with the old style crank bolt, the answer is yes! It's not a question of will it happen, it's a question of when it will happen! It's a 15min job to fix what will cost you much much more in time and money when it fails while your driving.
Q: But... A: No buts - FIX IT!
Q: But... A: But what?! Fix it!
Q: Bu.. A: Fix it!
[Re: DaphneD]
#543794
03/01/05 02:56 AM
It would also be nice to include some links to the aftermarket suppliers.
#543795
03/01/05 04:22 AM
I agree on the aftermarket links. I,ve only had mine for about a week, but i've spent hours upon hours searching. Very few sites even list mitsubishi,and when they do it usually comes up with nothing.
#543796
03/01/05 07:27 AM
It would also be nice to include some links to the aftermarket suppliers. Did you fix your crank bolt yet?! <img src="/forums/images/graemlins/pfft.gif" alt="" /> Aftermarket vendor links are generally located in the SPNR, also stickied at the top of the page. If you don't find what you're looking for there, click on the link in my sig. <img src="/forums/images/graemlins/wink.gif" alt="" />
'89 Raider 3.0L V6 (6G72) w/ AW372L (A44DL) A/T "The Millennium Falcon of automobiles"
[Re: Tag]
#543797
06/12/05 05:04 AM
This is a GREAT website! <img src="/forums/images/graemlins/smile.gif" alt="" /> Another-nice-to-have FAQ category - Recalls. Provide details like when you got it and quote the document verbatim. Seems I've missed some that I saw in these threads!<img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: DaphneD]
#543798
08/17/05 08:56 PM
I knwo this is ancient but its worth reviving... well, to me at least. Where can I find a list like this for my truck? 04 Montero Sport LS.
Any info would be greatly appreciated!
'04 Mitsubishi Montero Sport LS 4x4 3.5l SOHC V6 No locker, no LSD, no nothin' <img src="/forums/images/graemlins/frown.gif" alt="" /> 2.5" lift sittin on ProComp 1069 Xtreme Alloys wrapped with 33x12.50X16 Trxus-STS's Custom front end and sliders Enough Hella wattage to burn a hole in the sun
[Re: AZOutsider]
#543799
08/17/05 10:33 PM
One place to try is Montero Sport board .
None
