turn signal relay location? *DELETED* #545636 01/01/05 08:58 AM
MontyGrant Offline OP
Post deleted by MontyGrant
-Grant
'98 Montero with 135k miles
Re: turn signal relay location? [Re: MontyGrant] #545637 01/02/05 06:11 AM
The GenIs are up near the dash at the top of the driver's side kick panel. If no one posts on the GenII, I'll dig my FSM out from the garage and have a look...
Re: turn signal relay location? [Re: MontyGrant] #545638 01/02/05 07:52 AM
dadrab Offline
I believe, if it were mine, I'd replace a few bulbs first. That's the cheapest way to throw a few parts at it to see if it'll clear up. Replace every piece of glass in the circuit. I've seen some strange things happen to vehicles with a squirrely bulb.
If that fails, then go after the relay.
Hope you find it. <img src="/forums/images/graemlins/wink.gif" alt="" />
with awesome audio.
Re: turn signal relay location? [Re: dadrab] #545639 01/02/05 01:39 PM
V
v6lsmonty Offline
aw, dude you may be in for a real headache. I have a similiar problem. I tried new bulbs, turn signal switch, hazard switch, cleaning the column switch and nothing has worked for me. So now I'm looking for a new column switch w/headlight washers & cruise (anybody got one???), nearly impossible to find.
right now i have a turn bulb gerry rigged to the bumper, looks very "pimp" if i do say so myself...lol.
be careful when you change the switches on the gen I the hazard has a ground wire so I would disconnect the battery just to be sure.
let us know how it goes
1989 Montero LS (sold)
1994 Cherokee Country bone stock
Re: turn signal relay location? [Re: v6lsmonty] #545640 01/02/05 06:02 PM
52degrees Offline
You guys aren't very encouraging. I have the same problem with mine, ei; slow/stuck blinker in the morning esp. when cold.
Although, if I cycle the switch it works ok.
Clay
KG6VNX
Re: turn signal relay location? [Re: 52degrees] #545641 01/02/05 10:55 PM
V
vwiggi Offline
i am wondering if you solved the problem. i'm having a similar problem with my 1995 monty. the left turn signal is stuck on. the bulbs are fine. it's like the signal switch is stuck in the left postion.??????
help, VW
Re: turn signal relay location? [Re: vwiggi] #545642 01/03/05 12:23 AM
DaphneD Offline
relay relay relay. <img src="/forums/images/graemlins/wink.gif" alt="" />
...for the '95 LS
MR252921 - Relay (flasher unit), Hazard & Turn Signal
Located on the left wall of the driver's side footwell. Should be the one on the upper right of a grouping of about 5. Chances are the relay can probably be salvaged.
Re: turn signal relay location? [Re: DaphneD] #545643 01/04/05 09:53 AM
well boys, thanks for the responses. the strangest thing happened, for some reason the problem solved itself. i'm sure it is only temporary, but i was messing around and managed to get the lights on without the blinker coming on. i was driving at night, quickly turned my lights off, turned the blinker on, and then turned lights back on. when i did that, the blinker blinked and actually turned off when i put the lever back in the middle position.
for some reason i'm sure the problem will present itself again, at which time i will mess with the relay (thanks DougB)
-Grant
Re: turn signal relay location? [Re: MontyGrant] #545644 01/04/05 05:09 PM
DaphneD Offline
I had a similar problem last spring. I was able to solve it at first by turning on my hazard lights which seemed to awaken my turn signals. When it got worse, I simply unplugged and replugged the relay. It's been fine ever since, but I'm sure it'll be acting up again soon. <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6260 MB (Peak: 0.7302 MB) Data Comp: Off Server Time: 2026-06-07 08:37:23 UTC
