Transmission Failure!!?? - swap options? #545748 01/01/05 09:04 PM
airfooter Offline OP
My '84 4Runner must have copped an attitude after being parked longer than it liked. I did a standard road trip check, hopped in and 2 miles from home tranny didn't want to come out of 4th gear. After awhile, I persuaded it into 2nd (where it stayed) and limped back home. I took another truck on the trip and this apparently really pissed off the little Toy because when I got home I the trans was LOCKED UP. Now when I let the clutch out it stalls the engine (like e-brake is on or something). Truck only rolls w/clutch in or t-case in neutral...
This trans was rebuilt in Tampa (All Star Standard) about 50k ago. Wonder what happened?
I have a '88 V-6 5spd parts truck. I remember reading someplace this tranny would bolt up to 22R 5spd bellhousing. Is this true? What clutch disk do I use? Will my gear driven t-case bolt up? Any other mods req'd?
If I can swap, I'm gonna either put lower gears in t-case or go dual 'cases. (with the $$ I tell my wife I SAVED <img src="/forums/images/graemlins/evil.gif" alt="" />)
Thanks for any input.
1984 4Runner - V6 rear axle (locked by Lincoln), header, plenty of body cancer!
Waiting for install: x-over steering, dual 'cases, twin-stick, 3" body & drivetrain lift, rear springs up front
Still need: rear springs, 35" MT's, bumpers/sliders
2001 F350 - 7.3 110k miles on WVO conversion now!
Re: Transmission Failure!!?? - swap options? [Re: airfooter] #545749 01/02/05 01:16 AM
OOP'S Offline
Yeah it will bolt up, if you buy the adapter for it!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Transmission Failure!!?? - swap options? [Re: OOP'S] #545750 01/02/05 05:07 AM
kyle-22r Offline
V6 tranny needs a 22R turbo bellhousing, which in my searching tends to be about as easy to find as a football bat!
easiest bolt-in tranny will be a G52 or G54 if your truck is carbed
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Transmission Failure!!?? - swap options? [Re: kyle-22r] #545751 01/02/05 06:49 AM
G
Greg_Canada Offline
Touche!
Google came up with nothing (i had to check :P) <img src="/forums/images/graemlins/cheers.gif" alt="" />
89 4Runner
Re: Transmission Failure!!?? - swap options? [Re: Greg_Canada] #545752 01/02/05 05:06 PM
Red_Chili Offline
Toyota Section Staffer
It will be worlds easier just to rebuild your tranny yourself...
linkie
Waitaminit...
You sure its the tranny? Tcase in neutral, it rolls. So far, so good, expected if tranny. But clutch in, it rolls? Doesn't sound like tranny after all. Something binding up in your clutch? Bellhousing goofed up? I'm guessing here. Or is it possible you misspoke about it rolling with the clutch in? Will it shift with the motor off? Or is it still locked up? If it will shift with the motor off, but not with it running, it doesn't quite sound like the slam dunk it sounded like before. It may still be the tranny, but....
BTW, don't force it. My R151 for the article had been forced, it cost me an extra hundred dollars or so for the shift fork. Expensive little act of desperation on the part of the previous owner.
-Bill
Re: Transmission Failure!!?? - swap options? [Re: Red_Chili] #545753 01/03/05 04:32 AM
Marlin (www.marlincrawler.com) will sell u the proper 22R-TE bellhousing to mate your R150F gearbox to for $175. U need to ensure your gearbox has the short 160-165 mm (6.5 inch) input shaft. If it's the later R150F with a 190 mm (7.5 inch) input shaft it won't work. Also note unless u purchase an adapter your gearbox is designed to work with a chain drive transfer case, not the earlier gear driven one.
I also have a spare bellhousing.... I'd recommend you find a R151F gearbox from a 86-87 4x4 Toyota pickup truck. It will bolt directly to your 84 4Runners gear driven Tcase, provided you install a 23 spline input shaft, sourced from Marlin.
JR
Re: Transmission Failure!!?? - swap options? [Re: Red_Chili] #545754 01/03/05 03:18 PM
[/quote]
BTW, don't force it. My R151 for the article had been forced, it cost me an extra hundred dollars or so for the shift fork. Expensive little act of desperation on the part of the previous owner. [/quote]
I'm gonna go double check if it'll roll w/clutch in...
It does not shift EVER...
I suspected the driver forced shifter in wrong direction when problem first occurred. He hasn't driven much and he just got done driving my F-350 diesel 6spd, the toyota shifter only moves a fraction of the 6spd travel.
I took shifter off trans and tried to manually push/pull out of gear, its stuck... not that I had much leverage to move anything. Now it seems I can't get the shifter lined up right. It's flopping around everywhere... Could a shift fork have been bent to cause this whole problem? This tranny got a lot of new parts at rebuild and I have a lot of faith in the rebuilder.
Thanks for the input so far <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: Transmission Failure!!?? - swap options? [Re: airfooter] #545755 01/04/05 02:56 PM
OK, truck does not roll unless t-case is in neutral...
Any chance this is just a bent shift fork problem? This transmission has performed quietly and smoothly and even had its lube changed, since its rebuild 50k ago.
Re: Transmission Failure!!?? - swap options? [Re: airfooter] #545756 01/04/05 05:51 PM
Red_Chili Offline
Sounds like you engaged two gears at once. If the limit clip was forced off the shift rail, or something went awry with your interlock pin stack, its possible. Happened to my R151 before I bought it. Its also possible you blew a chunk off something and it found a new home between some teeth. <img src="/forums/images/graemlins/barf.gif" alt="" />
By far the easiest is, to rebuild your existing tranny, or have Marlin do it. Marlin can sell you the parts you need, Jim Sanville (referenced in the article above) is no longer in business.
-Bill
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6337 MB (Peak: 0.7406 MB) Data Comp: Off Server Time: 2026-11-17 11:01:49 UTC
