22RTE head question #546140 01/03/05 02:25 AM
A
alltracman78 Offline OP
So after reading about the water jackets rusting in the head, and since the engine I'm hoping to get has been sitting for like 7 years, is the 22RE head the same as the 22RTE? Don't care too much about valves, cam, ect. Just the head itself.
Thanks.
Jeremy
90/91 Celica GTS
91/92/93 Celica Alltrac
85 Toyota pu
Re: 22RTE head question [Re: alltracman78] #546141 01/03/05 03:42 AM
DirtyHarry Offline
Toyota Moderator
From last week:
http://www.4x4wire.com/forums/showf...;oldertype=&bodyprev=#Post645895
I run a normal 22RE head on my turbo truck though, as does Jeff Moskovitz and many others I am sure.
Re: 22RTE head question [Re: DirtyHarry] #546142 01/03/05 03:58 AM
A
Oh, thanks
Did you mess with it any? [the head]
When they say drop boost, they mean stock boost?!! Down 3-4 psi?
I'm pretty familiar with turbos, as far as tweaking I'm ok. ( the alltrac is fact turbo) I just don't know alot about these engines. [yet]
Jeremy
90/91 Celica GTS
85 Toyota pu
Re: 22RTE head question [Re: alltracman78] #546143 01/03/05 04:46 AM
DirtyHarry Offline
Toyota Moderator
Yes they are talking about lowering the stock boost, since the compression is higher from the normal RE head. The 22RTE has pathetic 7.3:1 compression though so I would not worry about it unless you start to have detonation issues.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6013 MB (Peak: 0.6574 MB) Data Comp: Off Server Time: 2026-06-23 03:11:34 UTC
