Rating: 5
Page 3 of 7 1 2 3 4 5 6 7
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: osirus] #547249 11/01/07 04:09 AM
DennisThompson Offline
If your talking about the intake gasket just get some gasket material and make a new one, other than that you will need to go to the dealer, no one wants to do that.
Dennis
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: DennisThompson] #547250 02/25/08 02:14 PM
homerdog Offline
Are NGK plugs ok to use, or is there a preferred brand I should be installing?
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: homerdog] #547251 02/25/08 03:06 PM
Axe Man Offline OP
Kia Moderator Emeritus
NGK's are the OEM plug so yes, they are OK to use.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: Hal2000] #547252 03/05/08 12:27 AM
LeadBelly Offline
I can't get the part numbers to bring up anything on the kia parts site. Is there a space somewhere that is missing?
I think I recall having troubles getting anything to display when I failed to fill in all of the input fields (# of doors, EX? etc.) If you still have trouble make sure you filled everything in...
leadbelly
'99 Sportage 4dr EX 5-speed, unmolested
'98 Sportage 4dr Auto 2wd
'96 Sportage 4dr Auto,235-75x29"tires, custom fabbed hidden receiver hitch and big plans.
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS #547253 04/29/08 05:57 PM
E
Enlew Offline
Did you find a blown spark plug? Cause mine is doing this and I think that is what we found.
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: Enlew] #547254 12/20/09 03:12 AM
Hydra747 Offline
Just changed the plugs today (and V-cover gasket)....used 4 spark Bosch.....They now sell them all covered with paper, and gap set was always supposedley pre-set! <img src="/forums/images/graemlins/kewl.gif" alt="" />
*dot not touch this pre-set gap*
....like I had done before <img src="/forums/images/graemlins/scared.gif" alt="" />
Engine idles perfect and I would not change a thing.
The reason that these plugs did not work for me before is prolly cause I tried to put the gap back to what we all are supposed to have.
Just don't touch them (except to put anti-sieze) on them!
Good luck... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: Hydra747] #547255 05/05/10 07:41 AM
L
LiorB Offline
Any recommendation on a specific brand? (I saw Denso for $24 and Karlyn for $51 or any other...)
Thanks,
Lior
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: LiorB] #547256 05/05/10 07:44 AM
L
LiorB Offline
Sorry, I forgot to mention I meant the plug wires... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: LiorB] #547257 05/08/10 05:27 PM
If yours is a DOHC all you need is 2 wires, The factory Kia wires are about all I've found. You didn't say what year Sportage you had.
Dennis
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: DennisThompson] #547258 05/09/10 03:34 PM
L
LiorB Offline
It's the DOHC (2001)
Thanks,
Lior
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6434 MB (Peak: 0.7663 MB) Data Comp: Off Server Time: 2026-05-29 14:54:32 UTC
