Toyota Solid Axle Widening Kit. #547430 01/04/05 07:28 PM
P
Packrat Offline OP
I just found this kit. Anyone tried it out yet? What IFS hubs will work on the solid front axle?
Beat to fit, Paint to match
Need a bigger hammer and more paint.
Did 75 Toyota (Downey 4X4 conversion Kit)
Building 88 Toyota 4X4 (7S Desert race truck)
Next 81 Toyota 4x4 (drive train conversion)
Re: Toyota Solid Axle Widening Kit. [Re: Packrat] #547431 01/04/05 08:42 PM
superv43 Offline
I installed the Sky wide axle kit on my '85 pickup to better match the '90 rear axle that I also installed for extra width.
Any of the '89-94 IFS front hubs should work. I also did the brake upgrade by using IFS calipers and Land Cruiser vented rotors. It all bolts up pretty easy, the only difficulty was drilling the holes for the extra pins on the rotor that Sky recommends in their kit.
Overall it seems like a much better setup than running a wheel spacer, and now the tire shops will balance my tires again. The local tire shops around here won't touch trucks with wheel spacers for liability reasons I guess.
Greg
Re: Toyota Solid Axle Widening Kit. [Re: superv43] #547432 01/04/05 09:33 PM
P
Packrat Offline OP
Thanks for the input. I like the wider track idea. Check out these other links. I have been asking around.
Sky Man. front wheel spacer kit
Re: Toyota Solid Axle Widening Kit. [Re: Packrat] #547433 01/04/05 11:35 PM
Red_Chili Offline
Toyota Section Staffer
My personal opinion, I'm with OOP's on this one. Eeek. You wanna fab up a driveshaft, go for it. You wanna weld on a through-the-frame solid axle mount, weld on, dude. You wanna screw around with caliper mounting on the front axle no less, I say, buy the widening kit and keep the stock proven mounting. Or let me know which highways you drive...
-Bill
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6016 MB (Peak: 0.6577 MB) Data Comp: Off Server Time: 2026-11-19 05:34:26 UTC
