empty inclometer ...what do i fill it with? #547689 01/05/05 03:59 AM
dieselguy Offline OP
Has anyone fixed a empty inclometer before ...is it alcohol in them or what liquid that won't freeze?
'87 Raider 4D56 ...lots of boost
'86 Toy xtra cab 2L-T
'82 Benz G Wagen 300GTD
'82 VW Caddy TD
'79 LJ81 Zuk p'up 1.6TD
Re: empty inclometer ...what do i fill it with? [Re: dieselguy] #547690 01/05/05 04:33 AM
First of all, I want to welcome you to the best Mitsubishi 4x4 (Montero, Raider, Montero Sport, Pick-Up) forum on the Net (our Aussie buddies may want to contest that) <img src="/forums/images/graemlins/lol.gif" alt="" />.
You can find the answer (full rebuild article) to that along with a number of other questions you may be asking in the Mitsu Section's Tech Articles/Write-ups.
In addition to searching the Tech Forums, the Technical Archives are another source of good information. If you'd like any help with the search feature, just let either Phil, DougH, or myself know.
Ray <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: empty inclometer ...what do i fill it with? [Re: dieselguy] #547691 01/05/05 05:38 AM
DaphneD Offline
Clear mineral oil which can be purchased at Wal-Mart. Do not use glycerin.
Re: empty inclometer ...what do i fill it with? [Re: DaphneD] #547692 01/05/05 05:52 AM
pmontero Offline
I used baby oil in mine. When it all leaked out again, now I can't smell the mildewed carpet anymore! <img src="/forums/images/graemlins/wink.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
Re: empty inclometer ...what do i fill it with? [Re: pmontero] #547693 01/05/05 06:00 AM
PHIL_ Offline
Re: empty inclometer ...what do i fill it with? [Re: pmontero] #547694 01/05/05 02:07 PM
dadrab Offline
pmontero and dieselguy,
When you seal up the unit, a trick I used last time I filled mine was to cut a piece of plastic so that it just fits inside the diameter of the back cover of the inclinometer. I used a Ruth's Chicken Salad lid; cut it down to approximate size and trim, trim, trimmed. I then RTV'ed the whole thing in so that flimsy little rear cover was total sealed.
It hasn't leaked down yet. <img src="/forums/images/graemlins/smile.gif" alt="" />
Oh, yeah - I used mineral oil as well and injected it with a veteranary syringe, but a turkey baster will work too.
with awesome audio.
Re: empty inclometer ...what do i fill it with? [Re: dadrab] #547695 01/05/05 04:18 PM
52degrees Offline
I just filled the entire rear section with sealant. Then I filled the seams too. Then I filled it with mineral oil and capped the hole with more sealant. I used GM's new grey RTV since it resists oil better than anything else I have ever seen.
Clay
KG6VNX
Re: empty inclometer ...what do i fill it with? [Re: 52degrees] #547696 01/05/05 06:12 PM
Jim_B Offline
I drained the last of the old oil out of mine and didn't bother refilling it. It bounces around a bit more than it used to but the inclinometer is (IMO) a bit of a gimmick anyway.
Re: empty inclometer ...what do i fill it with? [Re: Jim_B] #547697 01/10/05 09:44 AM
Thanx again guys for the great advice ...i tryed a search with no luck ...guess you just have to know the right words to whisper in it's ear
'82 VW Caddy TD
Re: empty inclinometer ...what do i fill it with? [Re: dieselguy] #547698 04/11/07 05:23 AM
ghostraider Offline
today i removed the inclinometer cluster from my raider. I did this to install two extra light bulbs and to grind guage faceplates edge down. This allows a lot more illumination for the volt and pressure guages.
my question is this. The inclinometer seemed to be empty of fluid. When i tilted the guage i never saw an air bubble. How do i know if it has fluid in it? Will there be an air bubble when tilted? How does it operate when full of fluid?
The guage seems very jerky all the time. <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
...by the way...my girlfriend pointed out that everyone has mispelled inclinomter!
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6413 MB (Peak: 0.7656 MB) Data Comp: Off Server Time: 2026-11-17 11:28:54 UTC
