alternator questions... #548098 01/05/05 11:37 PM
duffin_p Offline OP
I think my alternator might be going bad... when I step on the gas, my heater fan slows down and my lights dim a little... would I be correct in assuming this is an alternator problem? (I know, go get it tested, and I will, I'm just wondering if my guess is correct, before I take it to a shop)
If I need to replace it, should I go with a stock one, or upgrade to a more powerful one? I'm planning on installing a winch, lights and ARB lockers/compressor some time in the future....
With all of this stuff, will I need a larger alternator, or just a bigger battery?
thanks for the help,
Paul
'96 rodeo, 3" lift with both calmini and DOR parts, 265/75/r16's on Eagle alloys, K&N drop-in filter and flowmaster exhaust, superwinch hubs, TJM Bullbar, and a custom (home-made) rear bumper, and still working on it...
Re: alternator questions... [Re: duffin_p] #548099 01/06/05 12:22 AM
thepcguy Offline
If you've got a multimeter around you could check the output of the alternator while running. Should be in the range of 13.6 - 14.2V. If not, pull it and bring it in.
- Jim
1989 Isuzu Trooper II
- 2.6L 4ze1 Motor
- BFGoodrich 235/75/15 AT
Re: alternator questions... [Re: thepcguy] #548100 01/06/05 01:29 AM
Smiley Offline
Out of necessity, IÆve become something of an expert on this subject.
With my 1997 Rodeo, the general rule became ôWhen in doubt, swap it outö.
From the way that you phrased your questions, I will assume that youÆve already read-up on the subject (and if so, youÆve probably read at least one of the chapters of my alternator adventures), so IÆll skip past a whole bunch of the things that I would usually say, straight to this:
If you plan on running a winch, and a bunch of other accessoriesà then YES, you will most likely want a higher output alternator (at some point) û and probably a good-strong battery too.
All I can tell you about the 7 (or 8 û or maybe 9) remanufactured alternators that I had is thisà THEY STUNK! --- At the very least, get a NEW one û But since you plan to add all of those toys, you might want to get one the AlterStart units that IÆm getting soon.
(Sorry - YouÆll have to search æAlterStartÆ yourselfà Miss Kathy is calling for me <img src="/forums/images/graemlins/shiner.gif" alt="" /> )
HTH! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Cheers! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Smiley
Six Isuzus, so far... still have three of them.
Re: alternator questions... [Re: duffin_p] #548101 01/06/05 06:08 AM
RobG Offline
when you have your alternator tested, you need to make sure they check the output of the L terminal as well (which they typically overlook). The L-terminal supplys power directly to the blower fan... this is seperate from the normal charge wire.
Its possible to have an alternator thats pumping out normal charge to the battery, but has a faulty L-terminal and therefor no blower fan.
-Rob
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6023 MB (Peak: 0.6598 MB) Data Comp: Off Server Time: 2026-06-22 10:09:51 UTC
