Axle Ratio #548490 01/06/05 03:13 PM
VanillaGorilla Offline OP
Toyota lists 3 axle ratios for the Tacoma. How do you know which one you have? They are: 3.58, 3.73, and 3.91. I assume 3.58 is 2-wheel drive models (except prerunner), 3.73 is non-TRD prerunner and 4x4, and 3.91 is TRD prerunner and 4x4. Anyone know if this is right? Thanks.
Hang on, we're goin for a ride!
Re: Axle Ratio [Re: VanillaGorilla] #548491 01/07/05 04:45 AM
john_luttrell Offline
Mine came stock with 4.30 gears............and if i recall(too cold to go out and look) the gear code is B04A.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: Axle Ratio [Re: john_luttrell] #548492 01/07/05 04:29 PM
Red_Chili Offline
Toyota Section Staffer
Post your axle code and I'll look it up tonight. B03A is 4.10 2 pinion - mine.
-Bill
Re: Axle Ratio [Re: Red_Chili] #548493 01/11/05 09:24 PM
Red_Chili Offline
Here's the codes, FWIW:
B03A=4.10
B04A or B=4.556
B05B=4.70
B06A=3.909
B06B=4.875
The last A=2 pinion, the B=4 pinion. Sometimes the combo determines the ratio with a given middle number.
-Bill
Re: Axle Ratio [Re: Red_Chili] #548494 01/12/05 02:15 AM
Not doubting yer info, but I would love to know where ya found this at? thx...........
John Luttrell
Re: Axle Ratio [Re: Red_Chili] #548495 01/12/05 02:44 PM
superv43 Offline
Another one not often seen and documented;
B07A = 4.30
This is from my 01 Tacoma with 2.4l I4, 5 speed, 265/70-16 tires stock from the dealer. Ratio confirmed by jacking it up and counting driveshaft rotations.
Re: Axle Ratio [Re: john_luttrell] #548496 01/12/05 06:23 PM
Red_Chili Offline
An axle code sheet from the Toy dealer's parts guy. Toyota documentation. Thanks for that B07A number, I skipped that one because I thought it might be pretty rare, guess not.
Good to have the list handy when browsing the local boneyards... often a cheap way to regear.
-Bill
Re: Axle Ratio [Re: superv43] #548497 06/10/05 04:20 PM
little_joe Offline
Former Admin
B07A = 4.30
Bringing this one back up b/c I thought I scored a deal on a 4.30 diff.
My '04 std cab 4-cyl 5-spd 4WD tacoma is B07A. My buddy has an '01 4-cyl 5-spd TRD Xcab w/ rear locker that is also B07A. I was told repeatedly that B07A = 3.91.
I am going to confirm the ratio this weekend by also jacking it up and counting revs. If this bears out, this is excellent news. <img src="/forums/images/graemlins/smile.gif" alt="" />
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: Axle Ratio [Re: little_joe] #548498 06/10/05 08:02 PM
Sith Offline
As to the first post I have seen some 4wds w/ 3.58 gears. So it's not just a 2wd ratio
Where does he get all those wonderful toys?
98 Tacoma SAS'ed marlined dented rolled ect ect
04 Rubicon.wrecked soon to be new playtoy
05 Titan current concrete commando
Re: Axle Ratio [Re: Red_Chili] #548499 06/11/05 10:16 AM
B06A=3.909
B06B=4.875
That cant be right, no offense. The # code designates the ratio, for 06 to be 2 different ratios would be incorrect.
Here's a more accurate list, also 4.30 is a lot more common than you may think, same goes for the 3.58.
These are the most common if not all of the ratios that appear in Tacoma Prerunners and 4x4's.
02 = 3.58
03 = 4.10
04 = 4.56
06 = 3.91
07 = 4.30
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6370 MB (Peak: 0.7608 MB) Data Comp: Off Server Time: 2026-06-20 18:54:26 UTC
