gear ratio options for 8" 4cyl rear? #548749 01/07/05 03:26 AM
Little_Dog Offline OP
And now for something completely different...
I have stock 4.10 third members and a spare axle from an 85 4cyl 4WD toy. My son is building a street rod and would like to use my "free" rear axle. Can anyone guide me as to what if any 2 pinion 2WD third members will fit? I'm looking for a ratio between 3.2 to 3.55.
70 FJ40 under construction
Re: gear ratio options for 8" 4cyl rear? [Re: Little_Dog] #548750 01/07/05 03:34 AM
kyle-22r Offline
let me get this straight, your son is building a street rod and wants to use your 4x4 axle? remember,it's 6 lug. if you want a 5 lug 8" you need to find an earlier 2wd('69-78) as most if not all of them had the 5 lug 8", most 2wds got the 7.5 starting in the early 80s. however, just about every 2wd 4 speed or 1 ton rated truck came with the 8" too.
to answer your question about gears, i know the 8" came in 3.08 in some 2wd 4 speeds and also in 3.90. i DO know that 7.5s in 2wds were available with 3.42, 3.54 and 3.73 ratios, but i'm not entirely sure if you can get the 8" in a 3.54 ratio in the US(i've heard australia has them though)
all 8" diffs are interchangeable from '69-current. the only vehicles i know of that still have the 8" are 4runners, the last of them in trucks were used in '95
'91 4x4 shortbed
22R-E, W56, the dd!
Re: gear ratio options for 8" 4cyl rear? [Re: kyle-22r] #548751 01/07/05 03:54 AM
DirtyHarry Offline
Toyota Moderator
E-lockers used in Tacomas are 8". <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: gear ratio options for 8" 4cyl rear? [Re: kyle-22r] #548752 01/07/05 04:56 AM
Elbow_Greese Offline
Kyle-22r covered most of it.
The only thing I would add is that there were a few single wheel 2wd rear axles with the 4.10 and 4.30 ratios.
Hard to find though.
Most were dual rear wheels (think u-haul) and 6-lug, 4.10 and 4.30 ratios.
Hope this helps,
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: gear ratio options for 8" 4cyl rear? [Re: Elbow_Greese] #548753 01/07/05 07:17 AM
kyle-22r Offline
they're not hard to find! most if not all early-late 70s 2wds had a 5 lug, 8" rear end with 4.10 or 4.38 gears.
most 4 speed 2wds after that seemed to have a 3.08 8" rear end with 5 lugs as well
'91 4x4 shortbed
22R-E, W56, the dd!
Re: gear ratio options for 8" 4cyl rear? [Re: kyle-22r] #548754 01/08/05 12:07 AM
Thanks to all. Yeah, I was expecting to redrill the drums, etc. I was thinking this route because I was expecting to pay big bucks for a MOPAR or GM rear. NOT! I've found one from a Nova, non-posi 3.08, 8" 10 bolt for cheap.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6116 MB (Peak: 0.6819 MB) Data Comp: Off Server Time: 2026-11-18 03:28:11 UTC
