22RE Timing Chain Diagnosis Tips
#548862
01/07/05 08:52 AM
Engine has approximately 50K on it since a rebuild. Not sure how well it was rebuilt..... At start up it makes a noise like rod knock but it goes away after ~2-3 seconds - enough time to build oil pressure. The timing chain guides looked intact when I adjusted the valves approx. 10K ago. Any other ways to rule out (or in) the timing chain guides/tensioner/chain w/o taking off the valve cover?
Brian
Re: 22RE Timing Chain Diagnosis Tips
[Re: NVR FNSH]
#548863
01/07/05 02:03 PM
Put a timing light on it and see if it jumps around at idle or is smooth and steady.
It's worth a look under the valve cover when you consider what a broken chain might cause.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5859 MB (Peak: 0.6351 MB) Data Comp: Off Server Time: 2026-06-07 07:56:01 UTCValid HTML 5 and Valid CSS
