35-36's with 2 inch BL? #550685 01/11/05 10:05 AM
I want to run 35-36 super swampers on my 87 toyota. I have 2" of BL. I will hack my fenders thats not a problem. What I want to know is will I run into problems hacking my fenders that much? At the time I have 33 swampers on there now with a 4" trail master lift but Its so out of aliment and I have a death woble so I'm going to take it off.
Re: 35-36's with 2 inch BL? #550686 01/11/05 12:08 PM
kewlynx Offline
Are you running stock gears or something else? With a 22Rxx engine, you'd be robbing yourself putting big tires on, esp with the already added weight of a Runner vs. truck.
Any backspacing there?
**ubi apis- ibi salus**
Re: 35-36's with 2 inch BL? [Re: kewlynx] #550687 01/12/05 02:52 AM
well I would put in 5.29s for sure if I was putting on 35-36 inch tires. ya theres some back spacing. I know about robbing power. The 33's kill me.
Re: 35-36's with 2 inch BL? #550688 01/13/05 11:42 AM
anyone? If I hack the fenders that much will I cut into the fire wall? Or much less in to the cab?
Re: 35-36's with 2 inch BL? #550689 01/15/05 03:18 AM
someone?
Re: 35-36's with 2 inch BL? #550690 01/15/05 04:38 AM
azrain Offline
Well, I have not owned a 1st Gen. 4Runner, but I did own a '89 truck and I will say that as much as my 32's rubbed with a t-bar crank and an add-a-leaf (about 1") I would say you would have to do substantial cutting to fit that size tire let alone a bogger... Probably cutting into the firewall.
Mike
Re: 35-36's with 2 inch BL? [Re: azrain] #550691 01/17/05 10:36 AM
4
4mudder Offline
My buddy was runnin 33's on a 87 w/ a 3" bl and he was fine. I would crank the tbars and get an add-a-leaf to minimize the hacking, but you'll probably have to do some trimming. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 35-36's with 2 inch BL? [Re: 4mudder] #550692 01/19/05 08:47 PM
Johnyrrr Offline
on my buddys old 86, he had a 3inch body lift and cranked torsion bars/add-a-leaf with 36's for a while, with absolutly no hacking. with the 4 inch lift a 2inch body and cranking your torsion bars a little Ive seen 38's.
02 4x4 Sport
OME goodies and Brigestone 285's
Flowmaster 50 series(too loud), Alpine in-dash, with a suppertrapp on the tail-pipe to shut the thing up.
Re: 35-36's with 2 inch BL? [Re: Johnyrrr] #550693 01/20/05 05:00 AM
eightyeight Offline
My buddy is running 36x12.5 tsl's with a 3" body lift and no fender trimming. They rub a little, and the tires are pretty spanked, but they DO fit. This is on a '88 x-cab. I think a 2" BL would be pushing it a little with 36's. I would say 35's MAX, even with trimming.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: 35-36's with 2 inch BL? [Re: eightyeight] #550694 01/28/05 10:14 PM
right on thanks all.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6276 MB (Peak: 0.7329 MB) Data Comp: Off Server Time: 2026-06-09 10:02:28 UTC
